E-Body Cup Holders #2858976
12/12/20 02:41 PM
12/12/20 02:41 PM
Tampa FL
BillR1212 Offline OP
Tampa FL
Hi team,
I do a good bit of cruising and morning drives. Tired of spilling coffee on me when I'm driving. Anyone have pics of custom cup holder ideas that look okay? I have a pistol grip shifter column. so not much room to add something, and the generic window ones are not strong enough when accelerating.
Thanks!!
Re: E-Body Cup Holders [Re: BillR1212] #2858995
12/12/20 03:20 PM
12/12/20 03:20 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Got 1 that will knock your socks off for cheap- buy a section of pvc pipe- probably 2 or 2.5 " in diameter, depending on your container. Cut it at 4.5" tall. Buy a small sheet of pvc board in 24x24" if possible. Glue and screw said cut pipe to board, then jam it in between seat and console. Cut the height to fit your taste. You could also cut the pipe and or board at a slight angle.. Simple and non permanent. Did I mention cheap?
Re: E-Body Cup Holders [Re: moparjim79] #2859012
12/12/20 04:29 PM
12/12/20 04:29 PM
BDW Offline
BDW  Offline
$8 at Walmart and slides perfectly between console and seat
Re: E-Body Cup Holders [Re: BDW] #2859275
12/13/20 10:46 AM
12/13/20 10:46 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
That right there is probably the easiest option!
Re: E-Body Cup Holders [Re: BDW] #2859402
12/13/20 02:17 PM
12/13/20 02:17 PM
IMGTX Offline
IMGTX  Offline
I second the $8 Walmart option.
I have one in my Stealth because for some reason, known to only the sadist engineer who designed it, The factory cup holders are under the console lid, where your elbow rests. Totally worthless.
Re: E-Body Cup Holders [Re: IMGTX] #2859542
12/13/20 07:40 PM
12/13/20 07:40 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Well, it seems Walmart has discounted them to $14. But they are all over Ebay for $10 or so. I ordered one today.
Master, again and still
