Bench seat is 1970 chall and barracuda the same frame? #2859512
12/13/20 05:53 PM
12/13/20 05:53 PM
VA
jh27-1970 Offline OP
VA
Can a new cover for a 70 challenger go on a 70 barracuda frame? also is foam the same Thanks.
Re: Bench seat is 1970 chall and barracuda the same frame? [Re: jh27-1970] #2859538
12/13/20 07:23 PM
12/13/20 07:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Frames are the same.
Foam is different to match the upholstery type.
Several of the parts are also bench seat specific, the plastic backs and inner hinge covers were not used on anything else.
And if you have not done so yet, can you please remove the seat backs to check for broadcast sheets?
