Re: E-Body Cup Holders
[Re: BillR1212]
#2858995
12/12/20 03:20 PM
12/12/20 03:20 PM
Posts: 1,402 Central Pa
moparjim79
Central Pa
Got 1 that will knock your socks off for cheap- buy a section of pvc pipe- probably 2 or 2.5 " in diameter, depending on your container. Cut it at 4.5" tall. Buy a small sheet of pvc board in 24x24" if possible. Glue and screw said cut pipe to board, then jam it in between seat and console. Cut the height to fit your taste. You could also cut the pipe and or board at a slight angle.. Simple and non permanent. Did I mention cheap?
[Re: IMGTX]
#2859542
12/13/20 07:40 PM
12/13/20 07:40 PM
Posts: 12,008 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Well, it seems Walmart has discounted them to $14. But they are all over Ebay for $10 or so. I ordered one today.
Master, again and still
