70 Challenger ribbed non rallye dash #2858157
12/10/20 05:07 PM
12/10/20 05:07 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Wasnt it just 70 Challengers that got the ribbed non rallye dashes with the scalloped edge below the small gauges?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 70 Challenger ribbed non rallye dash [Re: 71TA] #2858168
12/10/20 05:19 PM
12/10/20 05:19 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
The ribbed version of the standard cluster was 70 Challenger.
Besides the different bezels, the gauges have different markings too.
Ever considered doing a gasket+insulator+anti-rattle kit for e-body Rallye gauge clusters?
Re: 70 Challenger ribbed non rallye dash [Re: skdmark] #2858201
12/10/20 06:35 PM
12/10/20 06:35 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I had started to look into it but a Canadian company, premiumdashdeacals.com makes them. I should carry them to resell here in the states. I dont make a product if someone is already doing a great job.
Re: 70 Challenger ribbed non rallye dash [Re: 71TA] #2858337
12/11/20 12:16 AM
12/11/20 12:16 AM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I do have one of their kits. Makes sense not to have overlapping products.
One thing it doesn't have are the 2 felt washers for the clock and the trip meter.
Re: 70 Challenger ribbed non rallye dash [Re: skdmark] #2858348
12/11/20 01:53 AM
12/11/20 01:53 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Need some? Have a picture and dimensions? I'm not familiar with those.
Re: 70 Challenger ribbed non rallye dash [Re: 71TA] #2858499
12/11/20 01:11 PM
12/11/20 01:11 PM
IMGTX Offline
IMGTX  Offline
My 70 Barracuda coupe has the ribs to I believe. I will check tonight or tomorrow.
Re: 70 Challenger ribbed non rallye dash [Re: IMGTX] #2858547
12/11/20 02:17 PM
12/11/20 02:17 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
The black felt washers I have from an original cluster are:
0.650" OD x 0.280" ID x 0.100" thick
They get sandwiched between the plastic bezel and the steel mounting plate backer for the woodgrain inlay. It looks like there was a tape like adhesive used on one side to hold them in place as well.
This would apply to 70-71 Rallye gauge clusters for e-bodies. Not sure if they were used elsewhere.
The OD cannot exceed 0.675". If it does it will overhang the pocket in the plastic bezel.
The ID cannot exceed 0.340". If it does the washers won't serve their purpose.
PCG was selling them as a pair for $5.00. Sadly, that is no longer an option anymore.
I've googled around and have not found a satisfactory off the shelf replacement (looked at felt washers used for brass musical instruments).
Image 1
Image 2
Re: 70 Challenger ribbed non rallye dash [Re: skdmark] #2861413
12/17/20 05:47 PM
12/17/20 05:47 PM
NJ
moparply Offline
moparply  Offline
NJ
Here is a picture of an original 1970 Challenger standard gauge bezel. This is a one year only 1970 Challenger only part.
The rectangular locating tabs are always broken off. Most don’t know they are supposed to be there.
The ones on this bezel are not broken off, it’s been in storage since 1980.
Re: 70 Challenger ribbed non rallye dash [Re: moparply] #2861424
12/17/20 06:18 PM
12/17/20 06:18 PM
NJ
moparply Offline
moparply  Offline
NJ
1970 Challenger Standard Gauges
Re: 70 Challenger ribbed non rallye dash [Re: skdmark] #2861480
12/17/20 08:31 PM
12/17/20 08:31 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I'll make these. I'll order the material tonight
