Passon 5 speed. Whos running one? #2854743
12/03/20 11:30 AM
12/03/20 11:30 AM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, picked up a Passon 5 speed this spring. Plan on putting it in my Challenger when it warms up here. Just curious who actually has one . And what you think of them, any issues, any tips? I remember hearing a story about then not staying in 4th. Is that a real issue with these? Thanks in advance.
Re: Passon 5 speed. Whos running one? [Re: 70VcodeCoronetRT] #2854747
12/03/20 11:48 AM
12/03/20 11:48 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have one of the earliest ones in my '70 'Cuda with a 493" RB, scattershield and American Powertrain hydraulic TO kit. I love it. Be sure to use the correct recommended gear oil in it and break it in as recommended. I found that 4.10's with 28" tall rear tires are a great match.
Re: Passon 5 speed. Whos running one? [Re: jbc426] #2854797
12/03/20 01:39 PM
12/03/20 01:39 PM
SW CO
HemiSportFury Offline
SW CO
How long did you have to wait for it, or did you find a secret supply to buy from?
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Passon 5 speed. Whos running one? [Re: 70VcodeCoronetRT] #2854873
12/03/20 05:08 PM
12/03/20 05:08 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
The one I installed went as close to factory as could be hoped. The only thing I remember needing to modify was the speedometer cable enters from the pass side. From the drivers seat the only give away its not an 833 is the shift pattern. Shifts exactly like a nice 833
Re: Passon 5 speed. Whos running one? [Re: HemiSportFury] #2855137
12/04/20 09:46 AM
12/04/20 09:46 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
List? What list? rolleyes
'63 Dodge 330
11.19 @ 121 mph
Re: Passon 5 speed. Whos running one? [Re: GY3] #2855495
12/04/20 11:13 PM
12/04/20 11:13 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I have one in my 6.1 Hemi 1969 Barracuda. I was #4 on the "list".. https://www.hemmings.com/stories/article/modernized-mopar-1969-plymouth-barracuda
Make sure you use a manual transmission GL4 oil and not GL5. Mine is a little notchy going into 3rd when cold but otherwise it works great.
HOWEVER, others have experienced significant problems https://www.forabodiesonly.com/mopar/threads/a855-5-speed.442999/
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Passon 5 speed. Whos running one? [Re: RealWing] #2855530
12/05/20 01:36 AM
12/05/20 01:36 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Wow!....that was quite an..."epic" sh!tshow to read...
Re: Passon 5 speed. Whos running one? [Re: DAYCLONA] #2855761
12/05/20 04:36 PM
12/05/20 04:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well then, that's one expensive POS I can cross off my list. Shameful.
Re: Passon 5 speed. Whos running one? [Re: RealWing] #2855846
12/05/20 09:27 PM
12/05/20 09:27 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Wow. I read the whole thing. That guy had a lot of patience! So, anyway, what's the best overdrive manual trans out there not the "Passon A-855?" Cause, you know, I'm gonna pass-on it
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Passon 5 speed. Whos running one? [Re: DAYCLONA] #2855899
12/06/20 03:12 AM
12/06/20 03:12 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
WOW....wow, wow.
Heck of a read. Thanks for sharing.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Passon 5 speed. Whos running one? [Re: metallicareload] #2855900
12/06/20 03:33 AM
12/06/20 03:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I just ordered a Tremec TKO 600 kit for my '70 Charger. I guess I'll let you know how this works out.
Re: Passon 5 speed. Whos running one? [Re: metallicareload] #2855918
12/06/20 09:09 AM
12/06/20 09:09 AM
E
earlymopar Offline
earlymopar  Offline
E
I did a little research on the Passon 5-speed in 2017 and ended up passing on it. I ended up buying a TKO-600 from Liberty's Gear for my 65 D100 and did the entire set-up from pieces I pulled together. Everything went well and I really like the transmission. The most time consuming part of the set up for my application was getting the pedal and clutch arm ratios dialed-in to have the best engagement / disengagement at the pedal. I opted for an external hydraulic (pulling) slave cylinder on mine.
Re: Passon 5 speed. Whos running one? [Re: earlymopar] #2855942
12/06/20 11:15 AM
12/06/20 11:15 AM
Nebraska
Nebraska
Damn why didn't I see that 6 months ago. Anyone interested in a 855 E body still in the crate? smile
Re: Passon 5 speed. Whos running one? [Re: 70VcodeCoronetRT] #2856106
12/06/20 03:35 PM
12/06/20 03:35 PM
Anchorage, Alaska
Anchorage, Alaska
Absolutely up I've heard there is some "massaging" needed, no big deal there. The big appeal here was drop out an A-833, lift the A-855 in place and in a few hours you had overdrive drive
Did you get that "refurbished" one that GFI was advertising on their site a little while back? I thought about it, but I didn't know how I'd go about getting in my B-Body
440, 4-Speed, 3.54
Re: Passon 5 speed. Whos running one? [Re: metallicareload] #2856113
12/06/20 03:42 PM
12/06/20 03:42 PM
Nebraska
Nebraska
No, I drove down to Wyoming and bought it from John.
Re: Passon 5 speed. Whos running one? [Re: 70VcodeCoronetRT] #2856140
12/06/20 04:45 PM
12/06/20 04:45 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Wyoming is north of you though, right /
Re: Passon 5 speed. Whos running one? [Re: Kern Dog] #2856150
12/06/20 05:26 PM
12/06/20 05:26 PM
Nebraska
Nebraska
I took the scenic route! smile Sorry, I drove northwest to Casper Wyoming. Loaded 2 transmissions in the back of my truck. And drove back southeast to get home.
Re: Passon 5 speed. Whos running one? [Re: 70VcodeCoronetRT] #2856211
12/06/20 07:40 PM
12/06/20 07:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I called him a couple of weeks back and was not impressed with his PP attitude over the phone. That in itself was enough for me. I know we're talking about a 5 spd here but my conversation was regarding a 4 spd. I have never been treated that way by Wayne at Brewers. twocents
Re: Passon 5 speed. Whos running one? [Re: RealWing] #2856431
12/07/20 10:28 AM
12/07/20 10:28 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Research on gear ratios and features like no cut install are easily decided in front of the computer but notchyness is something that is hard to get across on the internet. You must experience and feel it.
If this is a factor to you, like it is to RealWing. Get a T56 Magnum. Zero notchyness going on. It is not a straight bolt in but if quick shifting, smooth shifting, the highest power level capable and internal linkage are important to you, there is no other choice.
Re: Passon 5 speed. Whos running one? [Re: Magnum] #2856522
12/07/20 01:07 PM
12/07/20 01:07 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Wow, after reading about the Passon 5 speed issues I think I would have to pass on taking a chance with buying one. Good luck.
