Re: RR project 700 hp street/strip
[Re: hudsonhornet7x]
#2855087
12/04/20 06:39 AM
12/04/20 06:39 AM
Posts: 570 UK
rb446
UK
Nice looking car, certainly will be a handful with a stick, our mild 10:1cr 695hp '69RR 727 street/strip car (originally a stick) has the 11" drums with manual brakes/steering and is all steel apart from a 6-pk hood, owner says if you keep the drums adjusted well they work ok but boy they are seriously heavy, car weighs 3800@the line, 10.3's@129 with full exhausts to date, drive to station fill up with V-power in the morning up to the track, race and drive home the old school way.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2855103
12/04/20 08:33 AM
12/04/20 08:33 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Car looks beautiful Andy. Where can I find specs on the engine?
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: AndyF]
#2855138
12/04/20 09:48 AM
12/04/20 09:48 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
Car just got painted and is now in my shop for some work. Engine made a little over 700 hp with a Holley Sniper on top. Car might be a handful since it is a four speed. At least it is getting upgraded to disc brakes, The old drums weren't going to handle the power. Very nice paint job. The hood is fiberglass but it looks like steel. Even the bottom of the hood is smooth as glass. where did u get the hinges from
[Re: ChrgrCuda]
#2855202
12/04/20 12:57 PM
12/04/20 12:57 PM
Posts: 31,069 Oregon
AndyF
Car looks beautiful Andy. Where can I find specs on the engine? Engine is a 505 with Trick Flow 270 heads and a street roller cam. Compression is mid 10's so it runs on pump gas premium. Intake is ported. Nothing trick, just matched parts and good machine work.
[Re: AndyF]
#2855209
12/04/20 01:05 PM
12/04/20 01:05 PM
Posts: 4,699 Wichita
GY3
Wichita
Car looks beautiful Andy. Where can I find specs on the engine? Engine is a 505 with Trick Flow 270 heads and a street roller cam. Compression is mid 10's so it runs on pump gas premium. Intake is ported. Nothing trick, just matched parts and good machine work. Sounds like a really neat, user friendly combo. What does the top of the hood look like?
[Re: AndyF]
#2855241
12/04/20 02:03 PM
12/04/20 02:03 PM
ChrgrCuda
Texas, USA
Impressive as usual. Thanks Andy.
[Re: DirectConnection]
#2855438
12/04/20 08:39 PM
12/04/20 08:39 PM
AndyF
how is the clearance between the distributor and the head and valve cover what are the rear end gears The distributor clears the head and the valve cover just fine. I'm not sure on the rear gears, I think they are 4.10.
[Re: GY3]
#2855439
12/04/20 08:41 PM
12/04/20 08:41 PM
AndyF
Car looks beautiful Andy. Where can I find specs on the engine? Engine is a 505 with Trick Flow 270 heads and a street roller cam. Compression is mid 10's so it runs on pump gas premium. Intake is ported. Nothing trick, just matched parts and good machine work. Sounds like a really neat, user friendly combo. What does the top of the hood look like? Top of the hood looks like polished glass. This car was in the body shop for about a year and it was getting worked on, not sitting. I think it took them 2 months just to lay down the paint and then all the cutting and buffing.
[Re: AndyF]
#2855598
12/05/20 10:16 AM
12/05/20 10:16 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Beautiful! Is this a keeper for you Andy, or will you be selling?
2 kids and a dog
[Re: AndyF]
#2855714
12/05/20 02:12 PM
12/05/20 02:12 PM
TonyS451
Chicago, IL
Ah.. Certainly on par with the quality of stuff you put together! It isn't mine. Just in my shop for some work over the winter. My shop is heated so guys with project cars head my way in the winter for help with their projects.
2 kids and a dog
