Page 2 of 5 1 2 3 4 5
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854496
12/02/20 06:56 PM
12/02/20 06:56 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
21
124843987_3448563111859699_4968256928464305979_n.jpg124569075_3448563731859637_2095231903812628145_n.jpg124577967_3448563931859617_3276176059637921119_n.jpg
Contact Me about AMD Prices
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854497
12/02/20 06:56 PM
12/02/20 06:56 PM
South Dakota
South Dakota
22
124577967_3448563931859617_3276176059637921119_n.jpg125371296_3457122941003716_7254796390522040454_n.jpg125469556_3457123081003702_6980710432074537442_n.jpg
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854498
12/02/20 06:57 PM
12/02/20 06:57 PM
South Dakota
South Dakota
23
125338364_3457123637670313_4598414100521692229_n.jpg125308341_3457123697670307_3048766302295471856_n.jpg126508990_3473150696067607_222155341821479371_n.jpg
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854500
12/02/20 06:58 PM
12/02/20 06:58 PM
South Dakota
South Dakota
last one for tonight[. Body I just got in primer. Will be posting more pics on my shop facebook page. The NOS hood was stored in an old grainary that the roof started to come down on it. It had some wrinkles on the outer panel as well as I found a lot of the factory spot welds were either broken or never held. So I redid just about all of them as well as did some additional spots of welding in areas that I felt Chrysler should have had spot welds. Sure improved the way the hood flexed after that. Always seems like those 74 style hoods always flexed and twisted as you opened and shut them.
126399010_3473302589385751_8399191958087984187_n.jpg126899164_3475699322479411_484523263023639799_n.jpg127637809_3486808761368467_7119227881699496138_n.jpg
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854769
12/03/20 12:34 PM
12/03/20 12:34 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Wow, that's a lot of work but it's worth it when there is sentimental attachment involved. Cool to see a later A getting some love. Looks like you are doing great work. Keep this updated please.
Re: 74 360 4 speed Duster [Re: burdar] #2854834
12/03/20 03:31 PM
12/03/20 03:31 PM
South Dakota
South Dakota
thanks! I know there are ones that are thinking Why but with the use of NOS metal and AMD metal why not. It will never be worth what gets put in it but his boy is my age and has kept his grandpas jeep and will keep this car as well after the owner and his wife are gone. It will stay in the family. I am a firm believer that each car has a story to tell. Some just a few more stories and meaningful to some people. Below is all the metal I have done
Both qrts NOS
Both door skins NOS
Both fenders NOS
Hood NOS
Both outer rockers NOS
Tail panel AMD
Deck lid Used
Trunk floor AMD
Trunk drop offs L & R AMD
Left inner and outer wheel house AMD
Right outer wheel house AMD
Left rear frame rail AMD
Left rear spring mount AMD
Left front spring mount AMD
Under rear seal floor pan AMD
Rear shock mount AMD See the picture of what was welded in its place to mount the shocks!
main floor pan AMD
inner rockers patched
Both Rocker end caps AMD
all 4 door hinges AMD
Repaired 4 speed hump
Left inner fender panel AMD
Lower radiator support AMD
The car was completely media blasted inside and out then primed with PPG DP90LV primer. I did the metal work and seam sealed all the joints on the under side. Primed it with PPG epoxy and then coated the underside with Upol bed liner to give it some protection.
The car I believe was a rebuilder back in 75 or so. Owner I believe bought it around 76. It had been hit really hard on the left qrt. It had the drivers door and quarter panel replaced. There was evidence of some major damage both on the package tray and under the seat flor pan. as well as some on the inner left fender panel. I would almost guess it was side swiped from left front corner down the side. It is an original 360 4 speed car. Blaze Yellow with black side stripes and the V21 hood treatment. I am sure back in the day it was a pretty sharp car. Hoping that it will see color by years end. Speaking of color. Before I put the qrts and door skins on for the final time I chose why not color the areas behind those panels before welding them in place. Then come back and paint the areas that need to be. So look inside the rear panels on the qrts by back seat it is all yellow behind those areas as well as inside the door shells. Something I figured why not just get some PPG Shopline single stage yellow and coat those areas. Was just a little more instead of those areas just being epoxy primer coated. The inside trunk area is painted with PPG Concept as well as the under side of the hood. The interior floor pan is Shopline. Same thing figured paint those areas yellow and why buy the expensive paint when it will all be covered up anyway. I will be priming the body with PPG surfacer then when comes time to paint the body plan is to hang and paint body panels and do shell separately. Then assemble everything and do the V21 hood and install the side stripes. Owner will reassemble the car.
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854893
12/03/20 06:57 PM
12/03/20 06:57 PM
South Dakota
South Dakota
Body got primed yesterday with PPG DP90LV primer. I really like this stuff. Direct to metal epoxy that can be sanded and powders up like a surfacer. It dries with a semi gloss level so really can see what you need to focus on. Prime it with this stuff 2 coats. Let sit a couple days then block it out. Do any polester filler work that might need to be done then prime it with a regular primer surfacer.
129521286_3508716969177646_4350862680213126002_n.jpg129670238_3508717042510972_3084616703818168917_n.jpg129435542_3508717132510963_9039666681854608024_n.jpg
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854894
12/03/20 06:57 PM
12/03/20 06:57 PM
South Dakota
South Dakota
more
129032801_3508717219177621_7360212258050632110_n.jpg129477538_3508717342510942_4874106569487475882_n.jpg
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854895
12/03/20 07:00 PM
12/03/20 07:00 PM
South Dakota
South Dakota
The hood had some minor flaws that took a light filler work in a couple spots. Got that primed up today with regular surfacer. I had after media blasting primed it with PPG DP50LV epoxy. I took and blocked that out with 150 grit then could do my filler work on top of the epoxy. One coat of filler was all it took on the 3 spots then primed it with surfacer.
129646585_3511381585577851_1100644082624880550_n.jpg129638447_3511381635577846_7684971769283161863_n.jpg
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854896
12/03/20 07:02 PM
12/03/20 07:02 PM
South Dakota
South Dakota
found another of what it looked like in the field when I seen it after about 30 years. It had some coons making their home in it. Imagine they have been relocated by now. Probably in one of the other cars in the field.
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2854897
12/03/20 07:04 PM
12/03/20 07:04 PM
South Dakota
South Dakota
Anyone know if this is what the V21 hood looks like on a 74 duster? Looking for any good measurements of additional pictures if anyone has them.
Re: 74 360 4 speed Duster [Re: hotairballoonpilot] #2855783
12/05/20 06:16 PM
12/05/20 06:16 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
WOW! That is a SERIOUS project but after reading the backstory...I get it. You are doing a super job on it and he is going to be one happy guy when you're done.
65 Barracuda
70 Challenger
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2856634
12/07/20 03:49 PM
12/07/20 03:49 PM
South Dakota
South Dakota
Owner when he bought it at 15. He still has that hood tac.
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2860416
12/15/20 06:39 PM
12/15/20 06:39 PM
Land 'O Lakes
RoadRunnerLuva Online happy
RoadRunnerLuva  Online Happy
Land 'O Lakes
Cool backstory on this Duster! You are doing awesome work on it...looks great so far up I would like to find a nice 360 Duster with a factory sunroof...someday. Keep us posted on your progress!
Plymouth Makes It!
Re: 74 360 4 speed Duster V21 hood [Re: RoadRunnerLuva] #2864211
12/24/20 09:13 AM
12/24/20 09:13 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Cool car. If I'm not mistaken you own a 1972 V21 Cuda, and now you are restoring a Duster with family history? We seem to run on parallel paths
Re: 74 360 4 speed Duster V21 hood [Re: UCUDANT] #2874851
01/15/21 06:35 PM
01/15/21 06:35 PM
South Dakota
South Dakota
Yes dad owns the cuda. This one is owned by a friend. I always say these cars can tell a story some you just have to dig deeper. We are also doing an 85 Ford F250 for a guy. That one his grand dad bought new. Hauled campers all over the US racking up 350,000 miles on it before selling it. He found registration papers for it and was able to locate it by the vin and a favor from someone in the knowing of looking up information like that. He pulled into the guys yard to find him leaving with it on a trailer headed to scrap yard. He bought it. At 1st I thought ok redoing grand dads truck but have since learned that he was kidnapped when he was 18 months old and found when he was 5 years old and this truck is what his grand dad and dad drove from SD to kentucky to pick him up. So like I said just have to dig deeper and learn lots. Its fun and rewarding looking at it from those perspectives rather than just we are restoring a car or truck. makes it more rewarding
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2874852
01/15/21 06:37 PM
01/15/21 06:37 PM
South Dakota
South Dakota
it is in primer and will be blocking it. Just not rushing it with other work in the shop. Owner fine with that so that helps!
138912637_152542146474166_7668247592647903674_n.jpg138163158_1160068961075315_7011907573165567931_n.jpg138991429_134045868460049_7422799706218728226_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2874854
01/15/21 06:37 PM
01/15/21 06:37 PM
South Dakota
South Dakota
2 more
139411229_228681618839813_6328132678285285002_n.jpg139686259_4065394373470691_2860767652338372075_n.jpg
Re: 74 360 4 speed Duster V21 hood [Re: hotairballoonpilot] #2881424
01/28/21 06:12 PM
01/28/21 06:12 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Amazing work on a very cool car. Back in the day your rarely saw a 360 Duster and 4 spd every more rare.
Re: 74 360 4 speed Duster V21 hood [Re: 69Cuda340S] #2881429
01/28/21 07:00 PM
01/28/21 07:00 PM
South Dakota
South Dakota
Thanks. Not been working on it much the past 2 weeks. Other guy at the shop was out for Covid and the flood gates have opened up for other work. Just been trying to block on each panel as much as possible. Working each panel until I am happy with it then moving onto the next panel. Hand blocking always is a slow process so getting breaks between each panel sure helps my shoulders!
