Re: Removeable B-Body core support?
[Re: hudsonhornet7x]
#2854923
12/03/20 08:10 PM
12/03/20 08:10 PM
Posts: 4,205 New York
polyspheric
New York
My '63 Belvedere 426 MW had this done when I got it, it was sawed vertically and re-attached with tiny straps and 12-24 screws. Even though it's thin, it does work very well in tension, and a vertical 3/32" X 1" wide doubler strap on either side of each joint would make it stronger than the original. Low cost, low weight, can't hurt. You could make stripping faster with Dzus instead of screws.
Boffin Emeritus
#2854998
12/03/20 10:30 PM
12/03/20 10:30 PM
Posts: 22,695 Bitopia
jcc
Bitopia
They are flimsy, but they don't normally handle a large number of different loads. Mine is also removable, I lowered my rad, sectioned in a piece to deepen the removable upper member of the core support, then added openings for intake air, via a scoop /duct pictured later on. Its pic #44 https://board.moparts.org/ubbthread...e-62-polara-500-cruiser.html#Post1554309Pic #57 shows the bolted connection better
