Page 2 of 3 1 2 3
Re: Options for Overdrive Auto Trans - Ebody [Re: RoadRunner] #2854912
12/03/20 07:38 PM
12/03/20 07:38 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
IF the budget matters, the 518 goes in for 1/2 the price of the GM based ODs. And you do not have to mod the tunnel. With the torque that our big blocks make, the difference in 1st ratios is a non issue.
What is there to think about?
Master, again and still
Re: Options for Overdrive Auto Trans - Ebody [Re: DaveRS23] #2854939
12/03/20 08:40 PM
12/03/20 08:40 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The car below had a Gear Vendors attached to the 727. The OD wasn't all that great at .78. I JUST bought a Tremec 5 speed kit from Silver Sport....
Re: Options for Overdrive Auto Trans - Ebody [Re: DaveRS23] #2855084
12/04/20 05:17 AM
12/04/20 05:17 AM
None
71rm23 Offline
71rm23  Offline
None
Like I said, I'd rather keep it all Ma Mopar and the other thing to consider is that I'm hoping I don't have to mod the tunnel was the other thing. The tranny will be behind a 400 stroked to 470. Have you done this DaveRS?
Re: Options for Overdrive Auto Trans - Ebody [Re: 71rm23] #2855135
12/04/20 09:45 AM
12/04/20 09:45 AM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
Yes, I have. I posted a few details in an earlier post in this thread.
Re: Options for Overdrive Auto Trans - Ebody [Re: gtx6970] #2855353
12/04/20 05:36 PM
12/04/20 05:36 PM
BDW Online content
BDW  Online Content
Originally Posted by gtx6970
$6k can buy me A LOT of gas..It would take me YEARS to recoup the investment . even at 5 or 6 miles per
Bearing in mind I plan to drive the snot out of the car locally. BUT,,,,,,,and/if I should decide to make a longer distance trip. I'll rent a truck and trailer for a few days
You’re absolutely right, even the 518 doesn’t make financial sense for most.
I struggled with making the swap, because I’m cheap and always feel compelled to do a cost benefit analysis.
The 1 thing you can’t put a price on is enjoyment. I found myself not driving the car as much because it was so annoying running along at 4k RPM in the slow lane getting passed by minivans while my teeth rattled.
My only regret is not doing it sooner.
If you’re only doing city driving and stoplight to stoplight runs, save your money.
Re: Options for Overdrive Auto Trans - Ebody [Re: BDW] #2855418
12/04/20 07:46 PM
12/04/20 07:46 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
BDW nailed it.
I will also add your money invested into an engine build will last much longer. Overdrive is directly responsible for today's engines lasting 200,000 miles.
The days of a833's, 727's and 4.10 dump truck gears are over.
Mo' Farts
Moderated by "tbagger".
Re: Options for Overdrive Auto Trans - Ebody [Re: RoadRunner] #2855462
12/04/20 10:16 PM
12/04/20 10:16 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I finally pulled the trigger on a 518 for my 71 Barracuda when one popped up at a local you-pull-it. $250 and a fun afternoon later we had it out and loaded. I was on the fence for quite awhile, looking at all the different 4LXXe bell housing swap options. I wanted electronic control, but the fairly direct shifter hookup to my slapstick is a great trade-off. I plan to use 4.56s, which will give plenty of starting line ratio while still manageable with the OD for the highway. 3.06 for the 4L60 was actually a concern for me, that's quite a steep hit and I'm not planning to run Stock Eliminator.
However, am I wrong in thinking the low gear 727 gear sets would work in the 518s?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Options for Overdrive Auto Trans - Ebody [Re: DaveRS23] #2855644
12/05/20 11:59 AM
12/05/20 11:59 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Curious what the angle of the engine/trans is without modifying the tunnel. The 518 is even larger than most transmissions at the rear, and with it pointed down enough to clear the torsion bar crossmenber and floor, it must angle down at quite a large angle.
Re: Options for Overdrive Auto Trans - Ebody [Re: jbc426] #2855718
12/05/20 02:17 PM
12/05/20 02:17 PM
GA
roadrunninMark Offline
GA
Don't forget about the lil 42RH. Smaller body for a better fit and has the 2.74 first gear. You will definitely need to beef up the internals, but if you are doing a rebuild anyway, won't be that much more.
Re: Options for Overdrive Auto Trans - Ebody [Re: jbc426] #2855850
12/05/20 09:57 PM
12/05/20 09:57 PM
BDW Online content
BDW  Online Content
My 518 went in my Challenger and matched the 727 angle without mods to tunnel.
I shimmed it to 2 degrees downward.
Re: Options for Overdrive Auto Trans - Ebody [Re: BDW] #2855866
12/05/20 10:39 PM
12/05/20 10:39 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
How can you shim it down? That is not possible. A shim would raise the tail end.
Re: Options for Overdrive Auto Trans - Ebody [Re: BDW] #2856054
12/06/20 02:02 PM
12/06/20 02:02 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Wow, surprisingly good angle for no cutting of the tunnel metal.
Re: Options for Overdrive Auto Trans - Ebody [Re: jbc426] #2856411
12/07/20 09:38 AM
12/07/20 09:38 AM
Maryland
mrob Offline
mrob  Offline
Maryland
FYI, I did the A518 swap on my 73 Cuda 3 years ago. I was able to get a transmission tailshaft angle of 3.2 degrees down (below horizontal) without cutting the torsion bar crossmember. Any angle less than that will require notching the crossmember. So check for interference carefully before you install your transmission.
Re: Options for Overdrive Auto Trans - Ebody [Re: BDW] #2856449
12/07/20 11:06 AM
12/07/20 11:06 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This is the point i was trying to make
My car is not a long distance driver. More or a local cruise in and around town. Playtoy type of car.
I might take it to Phoenix once or twice a year.....maybe.
But.....if i do. Ill live with it at 65mph. .
Or ......I'll take back roads and see the country.
Anything farther than that. Ill rent a truck and trailer and haul it .
Re: Options for Overdrive Auto Trans - Ebody [Re: gtx6970] #2856480
12/07/20 11:49 AM
12/07/20 11:49 AM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
Unless you have 2.73s in your car, spend a weekend with an OD unit in your car and you will see what you have been missing. It makes it a different car. A better car and by every measure. Other than effort and money, there is absolutely no down side.
twocents
Re: Options for Overdrive Auto Trans - Ebody [Re: autoxcuda] #2857411
12/08/20 11:34 PM
12/08/20 11:34 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Originally Posted by autoxcuda
Originally Posted by Grizzly
To the Fellow who came up with the idea to notch the transmission case to make it fit: my hat is off to you. up Used to be a significant butcher job before the case notch.
44rh for me: more power to the wheels. twocents
I believe that was 1wildRT that came up with the notching.
Yep....it was Randy. Hate that he ain't here anymore! frown
Re: Options for Overdrive Auto Trans - Ebody [Re: Kern Dog] #2857550
12/09/20 10:55 AM
12/09/20 10:55 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Originally Posted by Frankenduster
To me, the down side of the 518 is the crappy 2.45 first gear ratio is a carryover from the 727. The 700R4/4L60E has a 3.06 first gear but second is a tall 1.62. That is a wide spread, sort of reminds me of the 833 OD 4 speed.
It may seem like crap on an rpm formula but that 2.45 is what we consider close ratio. This is ideal for powerful engines. You put the deep ratio in the rear and now you have less rpm drop between gears.
The 3 something ratios you speak of are from an era of gutless engines. The 4L60E and 833 OD are for moving heavy vehicles with weak engines off the light and with no consideration for big rpm drop between gears.
I hear what you are saying but until you have tried both, don't be shy of a tall 1st.
On an unrelated note. This is 518 vs NV3500. They soak up alot of power. I did a 518 swap in a truck. While climbing a bridge near me. I had to turn off the overdrive and unlock the converter to climb this bridge in 4rth. When I swapped to the 5 spd manual. At the same rpm I could easily climb the bridge in 5th gear. The same truck had a 3 mph increase in trap speed and 2 mpg improvement.
I am not saying a Silversport 4L60E would be any better than a 518 but after seeing the numbers for me, I'm not a fan of 518. The rpm change seems to be the only thing talked about but poor mileage in Ram1500's make me thing they are not the way to go.
Re: Options for Overdrive Auto Trans - Ebody [Re: Magnum] #2857626
12/09/20 02:24 PM
12/09/20 02:24 PM
moparx Offline
moparx  Offline
has anyone used a 518 with a manual valve body ? if so, was it a forward or reverse pattern ?
did you buy the valve body or change it over with a kit ?
as always, TIA. bow
beer
Re: Options for Overdrive Auto Trans - Ebody [Re: moparx] #2857809
12/09/20 08:59 PM
12/09/20 08:59 PM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
I have a forward manual valve body in my 518. The Hemi wants shifted at 6,800. To get the most out of it, manual shifting was the only real answer. Besides, I didn't want a strong hit going into 2nd and didn't want reverse to bang in with the 850 RPM idle.
I called A & A and they got it right the first time. It works good with the Slap Stick.
Re: Options for Overdrive Auto Trans - Ebody [Re: DaveRS23] #2857879
12/09/20 11:01 PM
12/09/20 11:01 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
how is overdrive engaged? with the manual valve body or through an electrical switch?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Page 2 of 3 1 2 3
