Door window track slider 71 Charger #2853423
11/30/20 03:55 PM
11/30/20 03:55 PM
Ohio
V
viperakron Offline OP
V
Ohio
Looking for advise on how best to remove the ball stud from the window linkage. Looks like it's press fit. Only need to replace this one without removing entire assembly. My plastic insert broke and the new part has the ball stud and plastic connected.
Re: Door window track slider 71 Charger [Re: viperakron] #2854252
12/02/20 11:41 AM
12/02/20 11:41 AM
IMGTX Offline
IMGTX  Offline
Do you have a slider yet?
Some companies make ones that snap on over the ball and others like this that clip on over the ball. They may and may not work but it may save you some trouble.
Otherwise I think you will have to grind & punch or drill it out.
