Question on headlight adjuster install
#2853462
11/30/20 05:19 PM
11/30/20 05:19 PM
Posts: 15,823 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
79 power wagon with the quad headlight set up. Received new headlight adjusters and screws from LMC truck. All the old ones were crumbling and falling out or already gone, leaving me nothing to go by for install. I know this isn’t exactly rocket science but I’m having trouble with it. One of the old ones that was still hanging there has the adjustment screw going in one way, however the new one has the adjustment screw going in from the other side (see photo). So I don’t know if the previous owner of the truck installed incorrectly or if LMC has the adjustment screws installed incorrectly for shipping, which I doubt. Can someone please explain how to put these in and dumb it down for me LOL?
Facts are stubborn things.
Re: Question on headlight adjuster install
[Re: larrymopar360]
#2853495
11/30/20 06:32 PM
11/30/20 06:32 PM
Posts: 1,964 Apollo, PA.
B1MAXX
Apollo, PA.
pretty sure the rusty one is correct so it won't pull through when tightened. The ones I have messed with pushed in from the front then pulled forward to catch the small wedge. Those just come in from the back. I'll look at my truck tonight.
[Re: B1MAXX]
#2853530
11/30/20 07:58 PM
11/30/20 07:58 PM
RWG75
RWG75
Doesn’t really matter - the tabs are gonna break off when ya tighten it down anyway. Keep the screws and use liscence plate nuts for the anchors.
[Re: ]
#2853766
12/01/20 12:47 PM
12/01/20 12:47 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Doesn’t really matter - the tabs are gonna break off when ya tighten it down anyway. Keep the screws and use liscence plate nuts for the anchors. But I'd like to try it the so-called right way, and if the tabs do break, I'll send them right back to LMC and get a refund. I do appreciate the suggestion on license plate nut anchors though. I hope the holes for headlight adjusters are standard size like license plate nut anchors. Thanks..
[Re: moparx]
#2853822
12/01/20 02:57 PM
12/01/20 02:57 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
my local ACE hardware has a selection of nylon "inserts" that push into round or square holes and expand tightly when the screw is inserted into the insert. maybe try something like that if the license plate inserts are the wrong size ? Excellent. I just looked at license plate anchors and they looked the wrong size (too small and square vs rectangular like I need). Thanks.
[Re: B1MAXX]
#2854270
12/02/20 12:18 PM
12/02/20 12:18 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I looked and mine go in from the front like your new ones. But mine aren't quite the same. They have a larger tab on the back like your front tabs unless your back tabs are bigger than what it looks like in your picture. Are they tabs or just a step? After looking at them I don't think that if the bullet nose was forward that the screw would go in deep enough before bottoming on the bullet. Back tabs are just a small fixed step in the nose on the new ones.
[Re: larrymopar360]
#2854353
12/02/20 02:04 PM
12/02/20 02:04 PM
RWG75
RWG75
Excellent. I just looked at license plate anchors and they looked the wrong size (too small and square vs rectangular like I need). Thanks. Not a perfect fit but they work. Tension from the bucket spring is enough to keep them in place - running em on one of mine now.
[Re: ]
#2854535
12/02/20 08:37 PM
12/02/20 08:37 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Excellent. I just looked at license plate anchors and they looked the wrong size (too small and square vs rectangular like I need). Thanks. Not a perfect fit but they work. Tension from the bucket spring is enough to keep them in place - running em on one of mine now. Okay, thanks I'm over these stupid things from LMC. I played with one and it snapped very easily, as you predicted. More chinese crap.
[Re: larrymopar360]
#2855155
12/04/20 10:36 AM
12/04/20 10:36 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Looked them over ten times and the only way the one LMC sent me is push in from front with the ears spreading out which causes most to snap off. I found a different style in the part store that says it’s for 72 through 78 trucks and I gave them a try and while not perfect they seem to be holding for now. They easily fit in and then with a pair of pliers I turned them to where they are locked. Once I started screwing in the headlight bolt they want to twist sometimes so I stop and twist back with pliers. I am waiting until I get the lights adjusted right where I want them before I put everything back on but so far they are holding. I only have one of the ones with the little ears installed and I gave up after that on those ones.
[Re: larrymopar360]
#2855156
12/04/20 10:40 AM
12/04/20 10:40 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
This is what they look like before installed (what I ended up using)
[Re: larrymopar360]
#2855298
12/04/20 03:39 PM
12/04/20 03:39 PM
RWG75
RWG75
Okay, thanks I'm over these stupid things from LMC. I played with one and it snapped very easily, as you predicted. More chinese crap. Been there, wasted that money and they've been crap for years. The 79 truck piece is nearly identical to the M body part and I haven't had one of those around here for at least a decade. Sometimes ya just gotta do what ya gotta do to get the thing down the road and yes, this actually worked.
[Re: ]
#2855658
12/05/20 12:25 PM
12/05/20 12:25 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
^ Your system looks like it will outlast mine for sure.
