Re: Keisler 5 speed and TTI's
[Re: Challenged]
#285275
04/11/09 11:16 PM
04/11/09 11:16 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
It's been mention in the pass and is normal according to Keisler. TTI has collecters at a slight angle (5 degrees?) to help out with this problem.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#285276
04/12/09 07:12 AM
04/12/09 07:12 AM
Posts: 2,521 Richmond Va, KeislerTKO 60...
VanishPt
Yep, mine do the same thing. I ended up lowering the motor about 1/4" which helped the angle a little. I also raised the rear of the trans to about 1/8" from hitting the cross member.
[Re: VanishPt]
#285277
04/12/09 08:12 AM
04/12/09 08:12 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I just went thru this with my Challenger 340/727 combo where my TTi collectors faced toward the ground. My TTi vendor told me to call TTi and I explained what I had and they shipped me two of the 5-6 degree collectors at no charge. I have installed them and now my collectors point back up a touch and now the ground clearance is about 1" better. The TTi guy said that they usually send these collectors when they know that a Keisler tranny is in the combo. Even though I do not have the Keisler, he did not even question my 727 combo having the same problem. I wonder if they have been running into this problem with either tranny.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Challenged]
#285280
04/13/09 06:38 AM
04/13/09 06:38 AM
YO7_A66
Indiana
Ed, Per your pm request, I have attached a side picture showing the reducers that came with the headers. you can see that the reducers point downward which lowers the rest of the exhaust. To me it appears that the header flange is pointing downward toward the ground once installed.
[Re: YO7_A66]
#285281
04/13/09 06:39 AM
04/13/09 06:39 AM
YO7_A66
Indiana
Ed, This is a picture of the 5 degree reducer that TTi sent me. I do not have installed pictures. This part definately helped out the ground clearance.
[Re: YO7_A66]
#285284
04/13/09 06:32 PM
04/13/09 06:32 PM
YO7_A66
Indiana
Ed, I took a quick picture tonight with the 5 degree reducer installed.
[Re: ThermoQuad]
#285287
04/14/09 09:59 AM
04/14/09 09:59 AM
Posts: 211 Tennessee
Keisler Sales
Tennessee
Tom,
Did you happen to notice earlier in the post the guy saying he had the same problem with his stock 727.
Tom I appreciate the tech post with the article, but the comments are uncalled for. Just because you in another vendors camp which by the way there product does the same. Plus requires more mods to the tunnel.This is the only way to install it with out getting into completely removing the top center of the torsion bar crossmember.
As an adder this article was on one of our 1st ever customers bought his Kit in 02 before some of the vast improvements we have made.
Keisler Engineering www.keislerauto.com#1 Choice of Overdrive Transmissions with Over 14,000 Sold
