Dash to cowl sealant ? #2852701
11/28/20 08:04 PM
11/28/20 08:04 PM
Southeast PA
5wndwcpe Offline OP
5wndwcpe  Offline OP
Southeast PA
'68 B body.
Does anyone know if the factory used any kind of material in between where the top of the dash and cowl meet ? I'm thinking there was a thin strip of butyl when I disassembled it, but I may be mis-remembering smirk
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Dash to cowl sealant ? [Re: 5wndwcpe] #2852706
11/28/20 08:25 PM
11/28/20 08:25 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I don't think so, they used a black sealer that went in the windshield gasket groove that kinda ran between the frame and body thru the years. The service manual says to fill the weatherstrip groove with sealer and to put a 3/8 bead across the cowl panel. I can tell you on my car there was no shortage of sealer there, on top of the dash, and, cowl pinch weld. On my car they ran that sealer up the a-pillar about 6" in the groove, and they had clear sealer between the glass and gasket, 6" up and all the way across the bottom. It also had clear in the upper corners, was the original untouched windshield. Run away from anyone that says no sealer is needed with a rubber gasket.
Re: Dash to cowl sealant ? [Re: 4406bbl] #2852785
11/29/20 01:13 AM
11/29/20 01:13 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
No sealer between the dash frame and cowl.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Dash to cowl sealant ? [Re: moparmarks] #2852841
11/29/20 11:28 AM
11/29/20 11:28 AM
Southeast PA
5wndwcpe Offline OP
5wndwcpe  Offline OP
Southeast PA
Thanks fellas.
1968 GTX hardtop
1933 Plymouth coupe
2015 Grand Cherokee
2013 Challenger
