Re: Dominator air bleeds
[Re: 493_DART]
#285264
04/14/09 09:37 PM
04/14/09 09:37 PM
Posts: 774 Southington Ct.
turbobitt
Southington Ct.
Try removing just the 4 inner bleeds. I think those are the high speed bleeds. Removing those should sut down the high speed circuit and any possible influence it can have on the idle circuit. If it cleans up the idle, then at least you have some sort of direction. Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: 493_DART]
#285266
04/14/09 10:04 PM
04/14/09 10:04 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
8082 is a 2 circuit
stock IAB is 71 and the high speed is 37
i think your tmming is to low.
my procedure is this, with carb off the car, i set throttle blades. install carb then set timming to desired idle rpm. if it wants 22* then i adjust dist to get the disired advance or lock it out. mine is basically at total at idle
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#285267
04/14/09 10:13 PM
04/14/09 10:13 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
yes sir--thats whats in it-- i should be able to fine tone my dist when the kit arrives. maybe my idle mix isnt as bad as i think.....i usually run the car in the garage...YES, the door is open....... it wont idle unless i have both blades/idle screws at around 2-3 turns and the mix screws around 1.5 turns out.....
