Re: 6 Pack tunnel ram [Re: polyspheric] #2852530
11/28/20 12:55 PM
11/28/20 12:55 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted by polyspheric
what it would cost to cast a few of those tops
Ten times what you would pay for it
At least that since I would have fabricated one myself a long time ago if I really wanted one. I was just curious.
Re: 6 Pack tunnel ram [Re: cudaman1969] #2852573
11/28/20 02:34 PM
11/28/20 02:34 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by cudaman1969
Or made out of plastic-carbon fiber
Hardwood and a router. Been done several times back in the 70’s.
And the calibration process on the Weiand was done in Michigan, and that was a scary process that an engineer came up with.
Re: 6 Pack tunnel ram [Re: A727Tflite] #2852617
11/28/20 04:00 PM
11/28/20 04:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Might look into that but no domestic types, maybe gum but I’m thinking imported with a very dense grain (heavy & $$). I’ll check my supplier next time I need some materials.
Also the Carters carbs line up nicely sitting on the front and back bolts of the two barrels (outermost bolts)
Re: 6 Pack tunnel ram [Re: cudaman1969] #2852635
11/28/20 04:43 PM
11/28/20 04:43 PM
GomangoCuda Offline
GomangoCuda  Offline
I seem to recall 7 ply baltic birch plywood. 20 years ago when I was thinking about making a top for 2 sideways Holley's I was going to make a spacer out of wood or nylon with an aluminum top. Then I realized I would probably need thermocouples and O2s in all 8 cylinders to figure out the extreme stagger that manifold needs. That is why a new, unused manifold and both tops are still in a rubbermaid bin.
