Which Differential Friction Modifier Oil? #2851585
11/25/20 09:32 PM
11/25/20 09:32 PM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
I have older Dodge truck with a recently rebuilt 9 1/4 using Yukon Limited Slip setup. I have receipts showing the shop used AT-210 Additive made by ATP. Looking around I see a few different things about modifiers but, wondering if I should use something different other than this product or just stick with what I have? I see Amsoil, Royal Purple, Motorcraft, and Yukon Gear have their own brand of modifier but, some look closely related even down to being the same size for fluid content. Thank you in advance for any help or information you could provide.
Re: Which Differential Friction Modifier Oil? [Re: OrangeProwler] #2851638
11/26/20 12:01 AM
11/26/20 12:01 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the shop added friction modifier why do you need to add it again?
Re: Which Differential Friction Modifier Oil? [Re: OrangeProwler] #2851784
11/26/20 12:29 PM
11/26/20 12:29 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Cass, a.k.a Dr Diff has always told me to use the Ford Racing Friction modifier. Add at least one bottle, and use 2 if you still get differential chatter. My local rear end shop recommends the same claiming that even though most dinosaur and synthetic gear oils are being produced with their own friction modifier these days.
The clutches in my Dana 60 started to chatter on turns after a while and I added a second bottle. It stopped it again.
Re: Which Differential Friction Modifier Oil? [Re: jbc426] #2851786
11/26/20 12:37 PM
11/26/20 12:37 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Same, I found the best deal buying it off of eBay.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Which Differential Friction Modifier Oil? [Re: GoodysGotaCuda] #2851804
11/26/20 01:12 PM
11/26/20 01:12 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
yesterday my shop Just put in a 9 1/4 Yukon limited slip unit I bought off ebay and it came with a bottle of the ford modifier.
Re: Which Differential Friction Modifier Oil? [Re: stumpy] #2851811
11/26/20 01:24 PM
11/26/20 01:24 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Pretty sure the OP was asking if what was used was best for what he had.
Re: Which Differential Friction Modifier Oil? [Re: old_racer] #2851854
11/26/20 02:49 PM
11/26/20 02:49 PM
moparx Offline
moparx  Offline
isn't that something, as yukon has their own stuff. laugh2
as was said, it seems the best buy on whichever product you like best is on the bag.
beer
Re: Which Differential Friction Modifier Oil? [Re: moparx] #2851997
11/26/20 09:44 PM
11/26/20 09:44 PM
BDW Offline
BDW  Offline
Another vote for the Ford stuff, initially had GM additive but was chattering, the good Dr recommended the Ford stuff and problem solved.
Re: Which Differential Friction Modifier Oil? [Re: BDW] #2852017
11/26/20 10:55 PM
11/26/20 10:55 PM
Middle of A Field
O
O
Middle of A Field
Thank you all again. All I saw the Ford stuff mentioned and then looked at some of the other stuff and thought hmm... a couple of these look similar to the Ford stuff right down to the size of the bottle.
Re: Which Differential Friction Modifier Oil? [Re: stumpy] #2852019
11/26/20 11:02 PM
11/26/20 11:02 PM
Middle of A Field
O
O
Middle of A Field
Stumpy, I'm planning to change the fluid/oil in the near future since it is fairly new and the rear end has around 3k mile since the last fluid change from the break-in period. So, it had one fluid change at around 500 miles or so and then I wanted to do this one since it has about about 2.5k to 3k miles from that change to inspect and make sure things are good to go since I bought the truck this way with the limited slip already installed.
Re: Which Differential Friction Modifier Oil? [Re: moparx] #2852023
11/26/20 11:05 PM
11/26/20 11:05 PM
Middle of A Field
O
O
Middle of A Field
beer
Yes, I was wondering if the Ford and Yukon are the same stuff. I'm willing to bet it is. Here is the link for the Yukon Modifier.
https://www.summitracing.com/parts/...fxd6h7QIVGHeGCh2AXg0DEAQYASABEgKdU_D_BwE
Re: Which Differential Friction Modifier Oil? [Re: OrangeProwler] #2852038
11/27/20 12:01 AM
11/27/20 12:01 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That answered my question . Thank you.
Re: Which Differential Friction Modifier Oil? [Re: stumpy] #2852104
11/27/20 10:56 AM
11/27/20 10:56 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
I use the FM that GM sells
Abe Lincoln
