Re: Mallory metal in crank [Re: 6PakBee] #2851930
11/26/20 05:16 PM
11/26/20 05:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The welder knew he would not be driving that car
Boffin Emeritus
Re: Mallory metal in crank [Re: polyspheric] #2851936
11/26/20 05:45 PM
11/26/20 05:45 PM
A727Tflite Offline
A727Tflite  Offline
Welding by Ray Charles and Stevie Wonder.
Re: Mallory metal in crank [Re: polyspheric] #2852324
11/27/20 08:51 PM
11/27/20 08:51 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Was the fact the welder is blind the giveaway? work grin
Re: Mallory metal in crank [Re: jcc] #2852339
11/27/20 09:17 PM
11/27/20 09:17 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
You can't weld steel 4340/4140/etc to tungsten, so what you're doing is welding a lip to the hole you're filling and making that solid. A TIG welder can put a little weave over those pieces in the crank without even taking it out of the engine. When going to heavier parts, you're often stuck filling holes with weld, vice trying to put tungsten into existing drilled holes where you'll have minimal press.
This isn't best practice, but no need to lose sleep over it once you get it TIG'd. S/F....Ken M
