8.0 V10 Help #2851143
11/24/20 09:49 PM
11/24/20 09:49 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
I have a 96 2500 Ram 4x4 that has the V10 engine. I'm in the middle of an engine swap and have hit a bunch snags. Is there any forums that specialize in the V10 truck engines. Some of the questions I need to find answers for are as follows. Is there a vin number some where on the block or a build date that will lead me to the year of the engine. What internal parts are interchangeable , Like crankshaft, camshaft, and timing parts so as I know the cam and crank sensors will work. Needing to take the 2 1/2 engines I have and stir the pot and have something good come out of it.
Thanks!
Re: 8.0 V10 Help [Re: mopar4ya] #2851206
11/25/20 12:54 AM
11/25/20 12:54 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Dodgetalk.com used to be my go-to, but I have not been on there for a long time. Definitely more technical Folks there like the race forum here.
Ramforumz.com and Dodgeforum.com are also out there but I found they were mostly tint, floormats, and mudflaps kind of users, but also, been a long time since I've been there, so perhaps it's changed? There is a V10 category: Link
Best of luck, you are on the right track to be swapping same year to same year............if nothing matches on those 2 and half engines you might be much aggravation less to sell what you have and buy the same year engine and stay on Easy Street.
Mo' Farts
Moderated by "tbagger".
Re: 8.0 V10 Help [Re: mopar4ya] #2851308
11/25/20 11:06 AM
11/25/20 11:06 AM
Guitar Jones Offline
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 8.0 V10 Help [Re: Guitar Jones] #2851702
11/26/20 09:36 AM
11/26/20 09:36 AM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Thank you! just what I was looking for. The 488magnum site is exactly the info I need.
Re: 8.0 V10 Help [Re: mopar4ya] #2852063
11/27/20 06:53 AM
11/27/20 06:53 AM
You are welcome.
