Page 2 of 3 1 2 3
Re: pick a solid roller for this combo [Re: mopar dave] #2849650
11/21/20 05:28 PM
11/21/20 05:28 PM
AndyF Offline
AndyF  Offline
Originally Posted by mopar dave
Ok, maybe i'm wrong here, but the .119" number was using clay to get that number.
That is fine but it doesn't really help you too much unless you know exactly where the cam was when you recorded the 0.119 number. The only practical solution is to use published numbers which is lift at TDC for the lobe. The cam catalogs usually publish lift at TDC and then you have to do a valve drop test to see how much room you have at TDC. Once you know those numbers then you can figure out which lobes will fit and which won't.
Re: pick a solid roller for this combo [Re: AndyF] #2849680
11/21/20 06:51 PM
11/21/20 06:51 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I rolled the engine with clay on top of the piston. I thought the best way was by measuring 10* ATDC?
Re: pick a solid roller for this combo [Re: mopar dave] #2849686
11/21/20 07:06 PM
11/21/20 07:06 PM
Mt Morris Michigan
Mt Morris Michigan
Anyone know what the limited is on piston to valve clearance?
Re: pick a solid roller for this combo [Re: mopar dave] #2849702
11/21/20 07:31 PM
11/21/20 07:31 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Piston is chasing the exhaust valve as it closes, and the smallest clearance is something like 5-10 deg BTDC.
The intake is opening before the piston starts down, so its clearance is the tightest at 5-10 ATDC.
Unless I got those backwards wink
Anyhow, the rule of thumb I usually see is around .080-.100 intake, .120-.140 exhaust - but if you're brave, you can run it closer until you start seeing witness marks on the piston top! scope
Re: pick a solid roller for this combo [Re: mopar dave] #2849743
11/21/20 09:15 PM
11/21/20 09:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
You determine how much P to V clearances you like shruggy
I've ran as little as .030 on the intakes and .060 on the exhaust accidently on my old NHRA M.W. Stocker after having the heads milled to NHRA blue print specs without thinking about rechecking the P to V clearances. That motor had its tongue out around 6400 RPM shruggy I'm thinking back then NHRA only allow stock Mopar valve springs specs. which were 110 Lbs. on the seats and and right at 300 Lbs. at .509 lift on both valves. I never had a bent valve or any evidence of valve hitting the pistons, I did see a lack of carbon build up on some of the pistons on the exhaust valve sides of those pistons with stock rods which had some of the pistons closer to the heads than others shock
I know many good SO CA Mopar engine builders that recommended .060 P. to V. clearances on the intakes and .080 on the exhaust on automatic tranny cars, .080 on the intakes and .100 on the exhaust side with stick shift cars back then with stock valve spring pressures shruggy
I'm good with .060+ on both valves with todays roller cams and valve springs twocents shruggy
Let me throw another rock into the pond on this discussion on P to V clearances with a solid lifter cam compared to a solid roller cam with the same specs and same LSA, I've seen a lot more P to V clearances on solid roller cams than with the same size solid lifter cams shock
My message is to make sure you check every motor for P to V clearnces on both sides of the motor and make sure and verify TDC on your balancer and degree wheel when setting the cam intake lobe center or verifying the LSA on your cam, check both the intake and exhaust lobes scope up
I've had more than one cam not be ground on the LSA that was stamped on the cam and cam card puke
Re: pick a solid roller for this combo [Re: mopar dave] #2849841
11/22/20 08:58 AM
11/22/20 08:58 AM
gregsdart Offline
gregsdart  Offline
I'm curious to your cam specs if you don't mind.
My specs are for a 15/1 compression 550 cube motor, so the specs won't compare. 285/296/114 with .867 int and .800ex lift.
On my 499 low deck motor with 13/1 compression and bowl ported 440-1 heads i ran a Ultradyne 283/290/108 with .740? And .680? Two things come to mind to help. That cam needed SPRING! I picked up a bunch by putting a 300+ seat pressure spring in it, and looking back there was more power available if i would have gone to a better pushrod. So if you have good enough valvetrain parts you can run a more agressive cam. That is why i mentioned Jones. You need a plan= lifters,pushrods,rockers, springs, all spec'd to fit the cam design or vise versa.
Re: pick a solid roller for this combo [Re: mopar dave] #2849843
11/22/20 09:03 AM
11/22/20 09:03 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
While that may not be the best way to tell it does tell you how tight it is at the tightest point. But since you don't know exactly where that point is it makes it hard to use that data to compare to another camshaft.
68 Barracuda Formula S 340
Re: pick a solid roller for this combo [Re: Bad340fish] #2850091
11/22/20 06:55 PM
11/22/20 06:55 PM
Mt Morris Michigan
Mt Morris Michigan
I didn't think where the tightest point was most important, just how tight it is? People have been using the clay method for decades. I know that is not the most accurate, but close enough i figured. My book says to check at 10* ATDC. I will have to get those measures before i buy, but was just fishing for opinions for now. Thanks
Re: pick a solid roller for this combo [Re: Cab_Burge] #2850094
11/22/20 06:58 PM
11/22/20 06:58 PM
Mt Morris Michigan
Mt Morris Michigan
Some interesting info here cab. At .060 i may be able to squeeze .060" lift in there. Will have to measure again and see. Thanks
Re: pick a solid roller for this combo [Re: gregsdart] #2850095
11/22/20 06:59 PM
11/22/20 06:59 PM
Mt Morris Michigan
Mt Morris Michigan
Good springs are on my list for sure.
Re: pick a solid roller for this combo [Re: AndyF] #2850421
11/23/20 12:41 PM
11/23/20 12:41 PM
Mt Morris Michigan
Mt Morris Michigan
I called comp and asked for the lift spec at TDC and they did not have that. They tell me the valve should be closed at TDC. I did find some of my notes and did find a valve drop spec at TDC , 368 on intake.
Re: pick a solid roller for this combo [Re: mopar dave] #2850425
11/23/20 12:54 PM
11/23/20 12:54 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Sounds like you talked to some idiot who didn't even understand the difference between TDC compression stroke and TDC overlap! spank
Re: pick a solid roller for this combo [Re: mopar dave] #2850426
11/23/20 12:55 PM
11/23/20 12:55 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
WOW......
Re: pick a solid roller for this combo [Re: mopar dave] #2850431
11/23/20 01:07 PM
11/23/20 01:07 PM
AndyF Offline
AndyF  Offline
Comp has a lobe catalog on their website that shows tappet lift at TDC for each lobe. An aggressive roller might have 0.150 tappet lift at TDC. Multiply that by your rocker arm ratio and that tells you the valve lift at TDC. If you have 1.70 rockers then the valve lift at TDC will be 0.255. Subtract that from your valve drop and you'll know what your valve to piston clearance will be with the new cam.
Re: pick a solid roller for this combo [Re: AndyF] #2850440
11/23/20 01:21 PM
11/23/20 01:21 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, I’ll see if I can find that.
Re: pick a solid roller for this combo [Re: mopar dave] #2850493
11/23/20 02:26 PM
11/23/20 02:26 PM
Mt Morris Michigan
Mt Morris Michigan
Lift is .141@106 and .124@110*. So .368-.141=.227?
Re: pick a solid roller for this combo [Re: mopar dave] #2850537
11/23/20 03:10 PM
11/23/20 03:10 PM
Never, NEVER ASSUME any math done on the theory of lift is accurate with your parts, NEVER tsk
To many ways for it to be wrong twocents
If you don't have a set of decent checking springs get them now before checking any thing related to valve to piston clearances, use a good dial indicator on the retainers align exactly like the valve stem is and push it down to the piston starting around .030 BTDC every 5 degrees until around .050 ATDC on both valves.
I learned a lot on actual P to V clearances and rocker arm ratio theory checking them this way up scope grin AKA this way is well worth doing twocents
Make sure and check the max valve lift at the retainers with the lash set also so you can figure out EXACTLY what ratio your rocker arms are scope wrench up
Re: pick a solid roller for this combo [Re: mopar dave] #2850542
11/23/20 03:11 PM
11/23/20 03:11 PM
AndyF Offline
AndyF  Offline
Don't you have rocker arms?
Re: pick a solid roller for this combo [Re: Cab_Burge] #2850589
11/23/20 04:45 PM
11/23/20 04:45 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
this is what i do when having any doubt
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: pick a solid roller for this combo [Re: AndyF] #2850597
11/23/20 04:55 PM
11/23/20 04:55 PM
Mt Morris Michigan
Mt Morris Michigan
HS 1.6 and 1.5 on exhaust.
Page 2 of 3 1 2 3
