Page 3 of 4 1 2 3 4
Re: Big Block Manual Trans Throttle Cable Bracket [Re: Joesixpack] #2839466
10/30/20 08:13 PM
10/30/20 08:13 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1 used 440 distributor hold down with bolt, cleaned $30
cowgerwilliam035@gmail.com
MAIN CAPS 009.JPG (1756 downloads)
MAIN CAPS 010.JPG (1735 downloads)
MAIN CAPS 011.JPG (1744 downloads)
MAIN CAPS 012.JPG (1735 downloads)
Re: Big Block Manual Trans Throttle Cable Bracket [Re: Joesixpack] #2839468
10/30/20 08:14 PM
10/30/20 08:14 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1 cam bolt&washer as removed from a 440, cleaned $15
MAIN CAPS 013.JPG (1731 downloads)
MAIN CAPS 014.JPG (1738 downloads)
Re: Big Block Manual Trans Throttle Cable Bracket [Re: Joesixpack] #2839476
10/30/20 08:32 PM
10/30/20 08:32 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
used 440 crank oil slinger, cleaned$15 2 440 intake manifold pan gasket end rails, cleaned and sanded with 220...$20
slinger 001.JPG (1715 downloads)
slinger 002.JPG (1714 downloads)
slinger 003.JPG (1716 downloads)
slinger 004.JPG (1714 downloads)
Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts] #2839664
10/31/20 09:44 AM
10/31/20 09:44 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
(( SOLD )) Team G 440 Intake. Been powder coated. Never milled.
$175 plus actual shipping to the lower 48.
For more info? Or quicker reply?
Call or text me at 423-402-6752
Thanks Moparts!!
Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts] #2839833
10/31/20 04:55 PM
10/31/20 04:55 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
SMR transmissions B/RB to small block transmission adapter kit. Part number SM99-1 OOP for a 6 bolt crank. New in box, the box has been opened but only for inspection, never installed the kit. It was for my 72 Truck project that never happened. $575 plus shipping, if using PayPal buyer pays all fees. email GTSDart340@yahoo.com or pm on here. Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
1972 Dodge D200 Adventurer - 318/727, eventually 440/518
2006 Dodge Magnum R/T "The Wagnum" - Hemi
2016 Dodge Durango Limited - 3.6
1970 383 Engine For Sale [Re: moparts] #2840149
11/01/20 12:22 PM
11/01/20 12:22 PM
Indy
N
Nuke463 Offline
Nuke463  Offline
N
Indy
1970 Mopar Dodge Plymouth 383 engine. Has steel crank and 906 heads. Needs rebuilt however it ran last year when my brother removed it. Engine came from a 1970 Sport Fury. Engine Build date is 11/13/69. Engine is 30 miles south of Indy. Am willing to deliver up to to 50 miles at my cost. If interested, let me know and I can send pic's.
$400.00 OBO
Thx
Nuke
Big Block Distributor Hold Down Bracket [Re: Memongo] #2840501
11/02/20 04:46 AM
11/02/20 04:46 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Distributor Hold Down Bracket. Used, $20 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only! Call Steve 810-629-1097
446" Drag Racing Bracket Engine $5500 [Re: moparts] #2842464
11/06/20 08:52 AM
11/06/20 08:52 AM
Jackson, GA
DADGUMDART Offline
DADGUMDART  Offline
Jackson, GA
446" / HP2 Block
XS29L9(6?)166683 stamping on RH pan rail
.030" Forged Pistons / 12:1 compression
Stock Forged Crank
.590 Purple Shaft Cam / Iron Adjustable Rockers
Weiand Tunnel Ram / (2) Holley 750 dp's [ Modified by JET Performance ]
( more info available on request )
Not a max-effort aluminum headed stroker engine--it was built for solid repeatable bracket duty.
Approx 580HP / Engine runs strong--used but not tired.
Ran mid-10's in 2850# '69 Dart [ 10.47 best ET ].
ENGINE IS CURRENTLY ON RUN STAND, so we can fire it up and see what you're getting [ no leaks or smoking / good oil pressure ].
Local pickup preferred, but reasonable delivery possible.
$5500 air cleaners to pan--or--$4000 without the tunnel ram & carb setup.
Best contact:
1) text at 714) 321-5770
2) pm me here on Moparts
3) you can leave a voicemail at 714) 321-5770 [ sorry, I won't answer phone calls---too many telemarketers ]
Thanks for the AD Moparts! up
Harland Sharp Rocker Arm Shafts – New [Re: DADGUMDART] #2843322
11/07/20 11:11 PM
11/07/20 11:11 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new pair of Harland Sharp rocker arm shafts for big block cylinder heads. Part number is PR7001-78. These are thick walled shafts for use with HS needle bearing rocker arms. These feature screw in end plugs and induction hardened steel construction.
Summit price is $263 for the pair. I will sell these for $220 shipped in the lower 48 states. I will sell internationally for the extra cost if any.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Re: JE pistons & Eagle H-beam rods [Re: Rocket] #2844780
11/11/20 09:39 AM
11/11/20 09:39 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
For sale- JE forged pistons with new total seal rings and Eagle 6.76 H-beam rods. Pistons have very little use- slight dome pad (+8.6cc) These will work with either a 4.15 stroker crank, or in a standard 3.75 stroke 440 and be 0.038 down (deck at 10.72) C/H 1.877
Calculated with a 4.15 stroker crank, 88cc #906 head to 11.74/1 compression with a 0.051 gasket and 0.008 down in my 440.
The JE piston is 4.375 bore (that's 55 over in a 440)
The Eagle rods have a standard mopar 1.094 pin and big end with ARP 8740 bolts.
Black Friday price- $649 shipped in the lower 48 via USPS priority box. Message me directly, thanks.
pistons pic1
pistons pic2
pistons pic3
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Several 440 blocks [Re: moparts] #2845208
11/12/20 08:14 AM
11/12/20 08:14 AM
KS
themopardude Offline
KS
79 440: Cast# 4006630-440-3, cast date 8-16-78, pad stamp 9T440E, build date 8-30, no serial # on pan rail, hot tanked, line honed, decks squared, .030 bore, block with caps, $1300
77 440: Cast# 4006630-440-4, cast date 10-6-76, pad stamp 7T440E, build date 10-15, no serial # on pan rail, .060 bore, block with caps, $495
77 440: Cast# 4006630-440-10, cast date 12-2-76, pad stamp 7T440E, build date 1-5, serial# 7????102, standard bore, hot tanked, block with caps, $595
77 440HP: Cast# 4006630-440-1, cast date 7-7-77, pad stamp 7T440EHP, build date 3-31, serial#7A239069, standard bore, block with caps, $595
75 440: Cast# 4006630-440-10, cast date 11-19-74, pad stamp 5T440E, build date 2-5, no serial # on pan rail, standard bore, block with caps, $595
74 440: Cast# 3830930-440-6, cast date 4-1-74, pad stamp 4T440, build date 4-15, no serial # on pan rail, hot tanked, magnafluxed, mains line honed, decks squared, fresh .060 bore, bare block with main caps, $1300
72 440: Cast# 2536430-9, cast date 5-14-71, pad stamp H440, build date 9-22, serial#2F137090, block with caps, fuel pump access hole will need a little work from plug being drilled out, standard bore, $525
69 440HP: Cast# 2536430-10, cast date 8-12-68, pad stamp E440HP, build date 9-11, Serial #RS23L9G126456. Bored .060, has 1 sleeve, very low run time, $450
67 440HP: All casting numbers removed, pad stamp C440 HP, build date 10-12, .060 bore, hot tanked, $450
All blocks will need qualified through a machine shop (cleaned and magnafluxed) unless otherwise noted. As with any used block, expect to bore, line hone and deck Can ship truck freight to anywhere in the world except Turkey and Afganistan. Questions call 620-340-7890.
Re: Several 440 blocks [Re: themopardude] #2845575
11/12/20 10:26 PM
11/12/20 10:26 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
Weiand 440 SIX PACK aluminum intake manifold, nice used condition $1200.00 (708)288-2879
parts 11-12-2020 004.JPG (1061 downloads)
parts 11-12-2020 006.JPG (1068 downloads)
parts 11-12-2020 009.JPG (1055 downloads)
Factory Big Block Valve Covers [Re: Memongo] #2845798
11/13/20 03:08 PM
11/13/20 03:08 PM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Big Block Valve Covers. Used, $50 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Note: All Harness Bracket And Wire Loom Bracket Are Intact.
Valve covers came off a 73 Charger.
Icon 400 block stroker pistons [Re: Memongo] #2846555
11/15/20 12:24 PM
11/15/20 12:24 PM
Wi.
old_racer Online content
old_racer  Online Content
Wi.
new set of 400 block 498 Icon forged pistons and rings set. .033 over. 400 bore. see info on box. or put part no. on summit web site. $660 in summit. $550 plus shipping. here.
B-Engine H beam Rods [Re: old_racer] #2846562
11/15/20 12:34 PM
11/15/20 12:34 PM
Wi.
Wi.
a friend picked these up, don't know brand , they are b-engine length, std rod journal, pin end will need bushings as it measures 1.156. they don't look to ever been run. they have arp 2000 eagle bolts in them. $200 plus shipping if someone can use them .
Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts] #2846677
11/15/20 04:17 PM
11/15/20 04:17 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
NEW - Edelbrock Pro-Flo XT Chrysler Big Block RB EFI Intake Manifold #7144
& XT Fuel Rail Kit #3644
Quote
The Pro-Flo XT Chrysler 440 #7144 EFI intake manifold is engineered with a large plenum and long tapered runners to deliver maximum horsepower and broad torque band throughout the rpm range 1500-7000 rpm. Features include a 90mm throttle bore opening. This manifold produced 20 more horsepower over our #35090 manifold at 5500 rpm. Accepts Pro-Flo XT throttle body #3869 or Ford throttle body #3818. Compatible with B/B Chrysler XT Fuel Rail Kit #3644
New Summit Manifold $548 - Fuel Rails $148
Save $450 for both with free shipping 48 states
Tom - In CT - Yes on PayPal to: tommoparts@gmail.com
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1983 CJ7 , 5.2 Magnum, 727, Dana 300/44/60
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
1970 440HP Clutch Fan Set Up [Re: moparts] #2847728
11/17/20 04:01 PM
11/17/20 04:01 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
Factory 67-71 Air Conditioning clutch fan set up, but will fit all 383/440's. Came off a 70 440HP so it probably is dated to that. Pulley spins easily, is tight with no wobble either. Is rusty looking so should be media blasted.
$200 shipped PO money order or check only please.
fas141@comcast.net
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
1970 440HP PS Pump Pulley and Bracket [Re: moparts] #2847730
11/17/20 04:04 PM
11/17/20 04:04 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
Taken off a '70 440HP. Spins easy, pulley is straight, return knob is tight, cap fits good. Is dirty and probably should be rebuilt.
$75 shipped PO money order or check only please.
fas141@comcast.net
RS23L7 440 4-Speed
RS27L7 440 727
Re: For Sale - Comp Cam [Re: moparts] #2849773
11/21/20 09:30 PM
11/21/20 09:30 PM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Older un-used Comp cam. Mechanical flat tappet. 3 bolt. Has card.
100.00
Plus shipping
SOLD
72 Satellite Sebring Plus 440, 69 Road Runner, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, .
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Throttle cable bracket [Re: moparts] #2850432
11/23/20 12:07 PM
11/23/20 12:07 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Throttle cable brackets
circa 1969 ??
One for a 4 speed $20 plus ship
One for auto $25 plus ship
PM for more info
BRKT 4 SPD.jpg (409 downloads)
BRKT AUTO.jpg (406 downloads)
Remember when cars were FUN?
Page 3 of 4 1 2 3 4
