F body floor shift column #2849380
11/21/20 04:56 AM
11/21/20 04:56 AM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
I have a '78 Volare I want to convert to a floor shift column. Will a '75 A body work?
Thanks! wave
Re: F body floor shift column [Re: slantzilla] #2849547
11/21/20 01:32 PM
11/21/20 01:32 PM
moparx Offline
moparx  Offline
anything can be "made" to work.
however, my gut feeling is, no, the two will not directly interchange.
the volare front suspension is a rubber isolation type, while the 75 A-body is not.
there may, or may not be a length difference, as well as the hook up to the steering box difference[s].
also, the under dash bracketry more than likely may be different as well as the wiring connector[s].
the best way to see is having them side by side to compare.
if that is not possible, i would continue the search for an F-body column.
just my opinion, your mileage will vary. at the least, this is a bump.
beer
Re: F body floor shift column [Re: moparx] #2849553
11/21/20 01:40 PM
11/21/20 01:40 PM
Park Forest, IL
Park Forest, IL
Thank you! I'm fairly F body illiterate. I only ended up with this one because I made an offer when I should have kept my mouth shut. laugh2
Re: F body floor shift column [Re: slantzilla] #2849574
11/21/20 02:26 PM
11/21/20 02:26 PM
moparx Offline
moparx  Offline
if you can fabricate things, i wouldn't worry about fitment. it just takes time.
i'm guessing you are looking to swap your column shift over to a floor shift ?
beer
Re: F body floor shift column [Re: moparx] #2849627
11/21/20 04:24 PM
11/21/20 04:24 PM
Park Forest, IL
Park Forest, IL
Yes. I can fabricate, I just don't want to.
Re: F body floor shift column [Re: moparx] #2849663
11/21/20 06:24 PM
11/21/20 06:24 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
beer
but the suspension is beyond the firewall..... I wouldn't let that stop me from trying if that was the column I had available. Maybe you can dismantle them and take the "bowl" off the A body column and put on the F body column.... so you at least lose the "column shifter bump"
Re: F body floor shift column [Re: volaredon] #2849673
11/21/20 06:36 PM
11/21/20 06:36 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Your plugs on your 78 harness will not work on a A body columns plugs.
Early 76-fs have the same type plugs as a 76 A body.
STOP POTATO HATE!
Re: F body floor shift column [Re: Mr PotatoHead] #2849677
11/21/20 06:46 PM
11/21/20 06:46 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
If your plugs are like this, I think they are, this could help you pm me, its from a late 77 that all was in good order, I also have a F extender can if your gonna use a tough wheel.
STOP POTATO HATE!
Re: F body floor shift column [Re: Mr PotatoHead] #2849790
11/21/20 11:25 PM
11/21/20 11:25 PM
Park Forest, IL
Park Forest, IL
I will be down by the car next weekend. I'll see what plugs are on mine. Thanks!
