Page 3 of 4 1 2 3 4
Aeromotive reg/taylor wires new [Re: littleredcoffin] #2841270
11/03/20 12:49 PM
11/03/20 12:49 PM
Suffolk County, New York
1mean340 Offline
1mean340  Offline
Aeromotive boost reference carb regulator PN 13204 new in box. $135 shipped
Taylor 10.4mm 409 series blue ignition wires for small block mopar PN 79668 new in box- $100 shipped
If interested, please E mail me at Kris396ss@gmail.com as I don't log in here too often to see and the account is linked to an old email. thanks!
Re: HOLLEY STRIP DOMINATOR $195 [Re: littleredcoffin] #2842268
11/05/20 06:35 PM
11/05/20 06:35 PM
Sacramento ca.
P
problemchild Offline
P
Sacramento ca.
Im interested in the intake please let me know if you still have and how to pay
timing chain cover [Re: moparts] #2843666
11/08/20 08:36 PM
11/08/20 08:36 PM
NH USA
littleredcoffin Offline
NH USA
Clean ,no damage..$20.calls only 603 209 1678.Payment by US POSTAL money order only
340/360 motor mount brackets [Re: moparts] #2843688
11/08/20 09:12 PM
11/08/20 09:12 PM
NH USA
NH USA
340/360 motor mount brackets..Very clean and rust free.$40pr.Calls only 603 209 1678.Payment by US postal money order only
DSC03929 (1).JPG (629 downloads)
DSC03930 (1).JPG (627 downloads)
oil filter adapter and bolt $20 [Re: moparts] #2843690
11/08/20 09:15 PM
11/08/20 09:15 PM
NH USA
NH USA
Oil filter adapter, with correct bolt $20.Calls only 603 209 1678/Payment by US POSTAL money order only
DSC03918 (1).JPG (621 downloads)
Factory complete mechanical rocker arm adjustment set $160 [Re: moparts] #2843692
11/08/20 09:20 PM
11/08/20 09:20 PM
NH USA
NH USA
Factory mechanical rocker arm adjustment set up with 16 straight pushrods...Will work on all small block LA engines..Very clean set..$160.Add 10-12 horsepower and 150-200 rpm`s to your engine
DSC03939 (1).JPG (622 downloads)
1979 standard 360 very clean block [Re: moparts] #2843694
11/08/20 09:25 PM
11/08/20 09:25 PM
NH USA
NH USA
1979 360 standard bore block. Still has factory hone marks in the cylinder bores..Super candidate for a stroker motor....$125.Pick up only .Calls only 603 209 1678.Payment by US POSTAL money order only
NEW Moroso 273-340 pan & pickup [Re: littleredcoffin] #2843951
11/09/20 10:57 AM
11/09/20 10:57 AM
So Near, Yet So Far
topside Online content
topside  Online Content
So Near, Yet So Far
Moroso #20710 8-quart pan and #24700 pickup.
New in box, never installed, decals & instructions still inbox.
$200 + shipping, which USPS quoted at $67 because of large box size.
UPS & FedEx were higher.
$340 new.
I have another ad in Race Parts section 1st page for this & other stuff
PM me here or email topside340@yahoo.com
X-Heads (Restored & Ported) [Re: moparts] #2846445
11/15/20 09:02 AM
11/15/20 09:02 AM
Macomb, MI
V
vinnyd76 Offline
vinnyd76  Offline
V
Macomb, MI
For sale are pair of freshly ported 340 X-Heads. The heads are ready to be bolted onto your small block Mopar engine. The heads were ported/assembled by a well known facility in Metro Detroit.
Below is a breakdown of the work that has been completed. Please note the heads have never been installed on an engine following the porting/reassembly processes.
Baked blasted and magnafluxed heads (no issues)
All tapped holes were chased
CNC Porting - intake ports / exhaust ports and chambers
Installed guide liners in the intake and exhaust guides
Installed harden seats in exhaust for unleaded fuel
Cut spring pockets to remove ID step
Cut for valve seals - cut top of guide for seals
Milled exhaust face - fly cut exhaust surface
Performed valve job - cut intake and exhaust seats and grind plus back cut valves (2.02/1.625)
Milled deck - 70cc
Installed freeze plugs
Washed and assembled heads with the following:
10-degree steel retainers
Comp Cams 10-degree 11/32" with no lash caps recess
Comp Cams dual valve springs 1.437 OD, 322 lbs./in. rate, 1.150" coil bind height
Comp Cams valve spring locator, steel, hardened, 1.500" outside diameter, 0.060" thick (set of 16)
Installed Manley valves - exhaust (stainless steel: 1.625", diameter: 0.3415", stem: 5.065" length)
Installed Manley valves - intake (stainless steel: 2.020", diameter: 0.3415", stem: 5.040" length)
If you have any questions, please let me know.
Price: $2,700.00
340 Ported Heads.jpg (419 downloads)
Ported 340 X Heads_2.jpg (414 downloads)
Ported 340 X Heads_3.jpg (418 downloads)
Ported 340 X Heads.jpg (413 downloads)
Milodon 8 Quart Oil Pan & Pickup for 360 [Re: vinnyd76] #2846803
11/15/20 09:17 PM
11/15/20 09:17 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a used Milodon 8 quart oil pan part # 30940 and matching pickup part # 18345 for sale. Good overall shape. Has some typical dings and scrapes from use. There are 3 small weld repairs that were made. They do not leak.
Price is $190 plus shipping cost.
PM me with questions.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Comp Push Rods 7692-16 [Re: Rocket] #2847045
11/16/20 01:08 PM
11/16/20 01:08 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
27 Comp Pushrods for sale part number 7692-16 11 of these are brand new, 16 are used. The description lists these as being for small block Mopar's with adjustable rocker arms the diameter is 5/16", the length is 7.342" for all of these.
$85 plus freight. PM me here or Clamb12 at gmail dot com.
SOLD thanks Mopart's
68 Barracuda Formula S 340
COMP on car valve spring compressor [Re: Bad340fish] #2847052
11/16/20 01:15 PM
11/16/20 01:15 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Comp on car valve spring compressor for small block Mopar. Part # 5323, I tried to use this one time and it DOES NOT WORK WITH "RACE" W2 heads but would work fine for stock style heads(non magnum) or ECONO W2 heads.
$100 plus freight. PM me here or email at Clamb12 at gmail dot com.
Sold, thanks Mopats
Re:Carter 600 cfm AFB Cometition Series carb #9605S [Re: Bad340fish] #2847584
11/17/20 12:27 PM
11/17/20 12:27 PM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a used Carter AFB 600 cfm Competition Series carburetor #9605S. It was taken off a running and driving car at the beginning of August so most likely does not need to be rebuilt. It looks to be in excellent shape. Also this carb is set up for a manual choke. I would like to get $125.50 for it shipped to any of the 50 States.
Edison, NJ
rider1454 at aol.com
Re:OEM SB rocker shafts [Re: PHYSIXX] #2847589
11/17/20 12:34 PM
11/17/20 12:34 PM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
I have for sale a pair of used SB OEM rocker arm shafts that look to be in decent condition and very usable. They show normal wear on the underside where the rockers ride, not bent or crushed on the ends. They have been cleaned and are ready for use. Although not in the pic, I found a third shaft that I will include with this pair but it's not been cleaned. I would like to get $8.00 for all three shafts, plus the shipping.
Edison, NJ
rider1454@aol.com
Small Block Chrome Valve Covers [Re: Memongo] #2848462
11/19/20 04:22 AM
11/19/20 04:22 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Small Block Chrome Valve Covers. Used, $175 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Call Steve 810-629-1097
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2848841
11/19/20 08:44 PM
11/19/20 08:44 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Selling for a friend...
Factory 1970 340 cast iron intake part number 3462848
He's asking $200 plus shipping to the lower 48.
For more pics or info call or text me at 423-402-6752
Thanks Moparts!
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2849042
11/20/20 11:52 AM
11/20/20 11:52 AM
Sacramento,California
JRepucci Offline
JRepucci  Offline
PETRONIX Ignitor Ignition Kit for small block with Prestolite distributor #1384, Retails for $100... new in box $50
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2849378
11/21/20 03:15 AM
11/21/20 03:15 AM
Nevada
X
x9daytonase Offline
x9daytonase  Offline
X
Nevada
Duel point distributor # 2642358 IBS 4013-B date 39 5 Looks to be in pretty nice shape missing one set of points. $200 Plus ride text 775 513 2317
Small Block Rocker Arm Shafts for Mechanical Rockers - New [Re: x9daytonase] #2850061
11/22/20 05:12 PM
11/22/20 05:12 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of small block Mopar rocker arm shafts for LA type cylinder heads. These shafts are made here in the U.S.. The shafts are made from thick induction hardened steel. They feature banana groves and oiling holes that are positioned for the loading of mechanical rocker arms (a little forward of straight down towards the valve spring). These shafts have screw in end plugs for inspection and easy cleaning. These are drilled on center for the hold down bolts and are for use with stock small block Mopar heads (273, 318, 340 & 360) or aftermarket cylinder heads including Edelbrock RPM, Indy LAX or other similar shaft mounted cylinder heads where mechanical rocker arms are being used. These are not intended for W2 or W5 heads.
These shafts will provide the proper oiling to high load areas for adjustable iron and aluminum rocker arms to minimize wear and maximize performance and parts life. They are far thicker and stiffer than stock or may aftermarket shafts to minimize flex with stiffer aftermarket valve springs.
Price is $180 for the pair shipped within the lower 48 states. I can ship internationally for the additional shipping cost.
Contact procketrichard@hotmail.com for more information and pictures.
SB Shafts Pic 1.jpg (108 downloads)
SB Shafts Pic 2.jpg (109 downloads)
SB Shafts Pic 3.jpg (106 downloads)
SB Shafts Pic 6.jpg (107 downloads)
Mallory HyFire 6AL Ignition module - Used [Re: Rocket] #2850078
11/22/20 05:37 PM
11/22/20 05:37 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a very nice used Mallory HyFire ignition module. It is in great shape and features a built in rev limiter that can be set by adjusted on the module.
Price is $150 shipped in the lower 48 states. I can ship internationally for the additional cost.
Hyfire 1.jpg (103 downloads)
Hyfire 2.jpg (105 downloads)
Hyfire 3.jpg (104 downloads)
Page 3 of 4 1 2 3 4
