Re: Cordoba steering column in a 74 roadrunner
[Re: IMGTX]
#3098276
11/30/22 07:59 AM
11/30/22 07:59 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
This lever is to activate the key in warning buzzer switch which is missed on this column.Nothing to do with any kind of lock system
[Re: chargers777]
#3098279
11/30/22 08:04 AM
11/30/22 08:04 AM
Posts: 19,849 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
We put a tilt/cruise column from a Cordoba into my 73 Coronet wagon. Easy swap, but the housing for the shifter, etc did not completely cover the portion of the column that was visible between the steering wheel and the dash. There was probably 2-3 inches of bare metal column visible, which I thought looked awful. Otherwise, very easy, worked great, no issues.
Earning every penny of that moderator paycheck.
DBAP
[Re: IMGTX]
#3098753
12/01/22 07:27 PM
12/01/22 07:27 PM
NachoRT74
Valencia, España
The switch pic is actually taken from rear side so it seems to be reversed to the cylinder pushing lever sense.
And about if the lever blocks the cylinder removal or not, really is not the goal in any case. The cylinder needs to get the lock button ( or lock lever on 70 assembly, not a bolt ) pressed anyway so the column needs to be 50% disassembled and will be easy to note visually the key is not needed for the cylinder removal like it’s needed on glove box cylinder.
But I got what you meant
