Shaker hoods - Why not offered on A or B bodies?
#2844996
11/11/20 05:57 PM
11/11/20 05:57 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I fell into a casual conversation with one of my brothers about Mopar options and stuff..
..and since Shakers look so cool, we got to thinking about the question.
Any idea why Ma Mopar limited the Shaker option to the E-bodies? ..were they only offered in '70 and '71?
Was it a marketing decision? Maybe the Shaker wasn't in high enough demand to expand its offering? Maybe something physical, like clearance in the engine bay? Too expensive in a shrinking market?
Anyone know or care to guess? - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Shaker hoods - Why not offered on A or B bodies?
[Re: skdmark]
#2846414
11/15/20 07:27 AM
11/15/20 07:27 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
years ago at the mopar nationals, a seen a mercedes with a shaker hood set up. didn't look to bad. maybe some one here has a pic
Hell Hath No Fury Like Mine
[Re: 67SATisfaction]
#2846463
11/15/20 10:59 AM
11/15/20 10:59 AM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
Probably the same reason Air Grabbers were not offered on E bodies. Each had it's own unique designs.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: sixpacksteve]
#2846637
11/15/20 03:37 PM
11/15/20 03:37 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
years ago at the mopar nationals, a seen a mercedes with a shaker hood set up. didn't look to bad. maybe some one here has a pic There was a write-up about that Benz in Mopar Action so might be in the archives I like the Cobra Jet shaker hoods on the big Fords they look good Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: skdmark]
#2846653
11/15/20 04:07 PM
11/15/20 04:07 PM
Posts: 21,495 N.E. OHIO, USA
A12
N.E. OHIO, USA
The baseplate adapter ring has the offset. Thanks guys, I was thinking the centering of the shaker might have been one of the reasons but sure doesn't look like that had anything to do with it, Some may not have noticed the offset of the air cleaner to the Air Grabber and the A12 hood underside versus the centered hood scoop but I guess that was never a problem for air intake/air filter/hood scoop location. The only thing that was ever (to my knowledge) a problem with a hood and hood scoop was told to me back in the '90's by Dick Maxwell regarding the lack of a method to close off the A12 scoop and take air in from a safe area inside the engine compartment like other Mopars and all of the other manufactures. This is what Dick Maxwell told me and I swear that it is true. In order to put a lift-off-hood on the A12 with no hood hinges and that if would not be necessary to disconnect any kind of a hood scoop intake closing system every time you removed the hood. He had to prove "to upper management" that the A12 could survive and stay running in wet or snowy weather. So he had the help of two other engineers and put an A12 on rear wheel rollers, put removable corner drain openings in the air filter tray and ran the A12 at half throttle on the rollers for nearly 30 minutes as he and one other engineer "hosed" the A12 hood with garden hoses in the mist pattern. Dick said that he convinced upper management that no one would ever drive a car with this much power at anything over half throttle in the RAIN OR SNOW. As we now know he convinced management to allow the LOH with no way to close off the hood scoop opening other than stuffing foam or a rag in it (suggested on labeling) to go into production, No other Mopar or any other manufacture has done that to this day that I know of? Ah the good old engineering days of Mopar and the Ramchargers MikeR
[Re: blaze]
#2846843
11/16/20 12:58 AM
11/16/20 12:58 AM
Posts: 22,900 Gabba Gabba Hey! NYC
Diego (not Ted)
The E-bodies were new for '70, so......maybe to draw attention to the new model? The A-bodies and B-bodies already had their own hood treatments. Maybe...I dunno...just a geuss The Shaker debuted in 1969 on the Mustang, and it was available through 1970. With the redesigned Torino for 1970, it was available through 1971. Pontiac introduced it with the Trans Am mid-year 1970 and was used through 1983, I think. When the Mustang was redesigned for 1971, Ford used NACA ducting for air induction. So if it was such an interesting and popular form of gimmickry, why did Ford discontinue it? Maybe because it was a gimmick, and there were more sophisticated ways to convey speed? And maybe Ma Mopar felt the same thing when the 1971 B-body was introduced? Another reason to think about is that 1972 was a year when performance was dead. The Shaker was just too much of a fussy item to deal with, and I know Pontiac had issues with new emissions rules and eventually make it non-functional, which would have been easy to do with a hood that was already standard on a model.....?
[Re: Diego (not Ted)]
#2846925
11/16/20 10:07 AM
11/16/20 10:07 AM
Posts: 7,363 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Another reason to think about is that 1972 was a year when performance was dead. The Shaker was just too much of a fussy item to deal with, Pure speculation but the later part of your statement make the most sense IMO. 72 is when you started seeing things being standardized across multiple car lines. The side markers were changed to a generic design that could be used on many different vehicles. That change alone had to save the company a lot of money. E-body door handles were also standardized. Hood pins, flip top gas caps and spoilers were gone in 72 as well. That's a lot less "fussy" items to deal with. Limiting the available options really saves the company money and makes things flow more smoothly on the assembly line. In 73 even more things were standardized. The E-body grills/header panels and tail light panels were carried over from 72. The fender mounted turn signals were changed to a generic design that was put on most of the other car models. The Challenger even used the Cuda vinyl top starting in 73.
