Re: 450 wheel rim shells used to make
[Re: duster2]
#2845423
11/12/20 03:59 PM
11/12/20 03:59 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
You all are missing my point , this guy took a pair of wheels , worth a good bit of money and made a pair of wheels worth a good bit less. Also if someone wanted to , they could buy these wheels , cut out the center and find a 14 inch big bolt center. Then you have a legit 2944450 wheel , worth a good bit of money. They would have the correct part number and some good date codes.
That's my point.. Frank
We get your point, but back in the early 80s these wheels were cheap and in the junkyards here in the Midwest, they would almost give you the steel wheels, $10-15 for the rallyes, just to get rid of the tires. We had yards that saved them and would buy pickup loads for $100, we would bust them down, take the tires to neighborhood cleanup for free, then a semi driver guy we knew would haul them to motor wheel, and bring finished 15x7s back. A guy here had them do a set of 15x7 small bolt chrome rallye wheels done for an a-body he had. I could be wrong on what was used but he had a set of 15x8 done with ramcharger or supercoupe hoops for his slicks.
