650 or 800 AVS2 #2843151
11/07/20 06:32 PM
11/07/20 06:32 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I have a fresh stock rebuild 71 440 HP in my GTX (mr. SixPack cam, & electronic distributor are only 2 changes). Automatic, 323 sure grip,
Changing out the original AVS for a new AVS2. Which is the best choice?
650 or 800cfm? I'll be going with an electric choke version.
Chris
Re: 650 or 800 AVS2 [Re: cdp] #2843164
11/07/20 06:57 PM
11/07/20 06:57 PM
AndyF Offline
AndyF  Offline
I put the smaller one on there.
Re: 650 or 800 AVS2 [Re: cdp] #2843205
11/07/20 08:06 PM
11/07/20 08:06 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Have you looked at the Street Demon carbs? They have some real advantages over the decrepit CarterBrocks. Plenty of tests and reviews on the 'tube. Here are just a couple;
www.youtube.com/watch?v=DPOuEOkazVc&t=275s
https://www.youtube.com/watch?v=YNAlVFtUFL4
Master, again and still
Re: 650 or 800 AVS2 [Re: DaveRS23] #2843247
11/07/20 09:33 PM
11/07/20 09:33 PM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
A year ago I bought an 650 Eddy AVS2 to put on my 440 in my Crown Coupe. Before I did that I tried it on my stock 440 Magnum in my Charger to see how it would work on it. What I noticed was that the idle was more smoother and basically drove nicer threw out the rpm scale. I also thought that it felt like it was a little down on power at full throttle compared to the factory Carter AVS. I want to emphasize...just a little.
Personally I would go with the 800 AVS2.
1969 Super Bee Six Pack
1969 Charger R/T SE
1968 Crown Coupe
Re: 650 or 800 AVS2 [Re: WORKER_BEE] #2843383
11/08/20 10:05 AM
11/08/20 10:05 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
The reason those new AVS2 carbs are so responsive is that the primarys are choked for flow with those HUGE annular boosters stuffed in there.
I bought a pair of the 800's to use on a crossram, I tried them on the flow bench and they only flowed around 700 cfm!! They were sent back and standard booster 800's were used.
Re: 650 or 800 AVS2 [Re: powertrip] #2843534
11/08/20 04:07 PM
11/08/20 04:07 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
Why the standard boosters flow more
Re: 650 or 800 AVS2 [Re: cdp] #2843659
11/08/20 09:14 PM
11/08/20 09:14 PM
I would put a 750 or 780 vacuum secondary Holley carb on it twocents scope
Re: 650 or 800 AVS2 [Re: Cab_Burge] #2843714
11/08/20 11:22 PM
11/08/20 11:22 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
I run the 800 Thunder series AVS carbs on a couple of my big blocks and really like them, they are very responsive.
Re: 650 or 800 AVS2 [Re: chargerbr549] #2843854
11/09/20 09:41 AM
11/09/20 09:41 AM
an8sec70cuda Offline
750 minimum
CHIP
'06 GMC 2500HD LBZ Duramax
