Re: 4.375 Stroke Pistons
[Re: 65Fury440]
#2874178
01/14/21 10:52 AM
01/14/21 10:52 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Okay...... clearly a non-symmetrical valve pocket arrangement in that piston.
I’d be getting out the clay....... and also checking to see if the valve that made contact is now bent.
[Re: 65Fury440]
#2874460
01/14/21 08:06 PM
01/14/21 08:06 PM
fast68plymouth
So. Burlington, Vt.
The pic of the witness mark in that one piston is way way off. Are the other witness marks located in about the same place?
I have sold several stroker rotating assemblies with Icon pistons, no reports of any v/p clearance issues. Big variety of heads have been used with them.
Since these aren’t motors I’m assembling, I don’t know how thorough the mock up and inspection is.
I saw this pic posted a while back...... 440 Source 512 low deck kit, Indy 440-1 heads(bigger ex valve than the TF head).
From what I can tell by judging this one pic...... at least from this angle...... it doesn’t appear that the exhaust valve is centered in the pocket all that well(but I def wouldn’t consider it a definitive answer), but the valve doesn’t seem to land outside the pocket.
[Re: 65Fury440]
#2874669
01/15/21 11:40 AM
01/15/21 11:40 AM
Posts: 4,206 New York
polyspheric
New York
That's way harder than a witness mark. Aluminum does not bounce back from being struck the way steel sometimes does.
Boffin Emeritus
[Re: polyspheric]
#2874876
01/15/21 07:25 PM
01/15/21 07:25 PM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
@440sourcedotcom Do the pistons in your new 4.375 stroke kits clear the exhaust valve radially for the TrickFlow heads?
[Re: 65Fury440]
#2874940
01/15/21 11:06 PM
01/15/21 11:06 PM
Posts: 3,021 NY
B1duster
NY
Ok, unless the valve is bent, the rod is bent, or that piston was machined wrong, those pistons will work with those heads. I better be right because I have 2 of my own motors I’m putting together with icon pistons. One has edelbrock heads and the other TrickFlow. You only need to put that head back on and use clay like was suggested. Even if you remove that spring, check that the valve is not bent and push it down into the clay by hand, you’ll know if it fits the pocket Stealth is the same as Edelbrock 2.14 and 1.81, so there is more room for the exhaust valve with the TrickFlows. All 3 have the valves in the stock location Then you’ll need to clay it up, like fast68 suggested and check with your new cam http://store.440source.com/Pistons/departments/7/
[Re: B1duster]
#2874946
01/15/21 11:29 PM
01/15/21 11:29 PM
65Fury440
Spring Hill Fl
The over rev incident was early on, ran it 3 more years before this tear down. There is nothing bent that would make multiple valves kiss pistons, except maybe my wallet. I am getting new pistons either way, just on the fence about how high to go with the compression. Thanks for all your help!
[Re: B1duster]
#2875165
01/16/21 04:56 PM
01/16/21 04:56 PM
65Fury440
Spring Hill Fl
I seen that on FB. Wonder where the exhaust valves were on his pistons. As I recall, he just bought the car and tore it down to sell. Not a bad deal, if it were all kosher.
