Re: ‘55 Dodge Pickup on ‘93 Dakota Frame
[Re: HWC]
#2842474
11/06/20 10:06 AM
11/06/20 10:06 AM
Posts: 34,909 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
About the only thing you could do is get correct offset wheels to make up some of the difference .. how for off is it ?
<--not a big fan of frame swaps
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#2842479
11/06/20 10:16 AM
11/06/20 10:16 AM
Posts: 20 Great Falls, MT
HWC
Great Falls, MT
About 8”. Could you please tell me what an offset wheel is and is that something you get at Summit or a place like it or can you get them at the wrecking yard? Thanks, Wayne
[Re: HWC]
#2842492
11/06/20 10:48 AM
11/06/20 10:48 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
8 total would be 4 each side // be tough to move them in that far ..see chart
[Re: poorboy]
#2842895
11/07/20 09:33 AM
11/07/20 09:33 AM
Posts: 237 British Columbia, Canada
Old Ray
Is your 55 a big truck, like a 1 ton or bigger? The 68" wheel track sounds awfully wide to me. I echo what Gene said. Would my '56 wagon with Dakota sub-frame be that much narrower than a '55 half ton pickup ? The track is close. ]
[Re: Old Ray]
#2842932
11/07/20 11:23 AM
11/07/20 11:23 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Are you measuring it correct ?
[Re: bigdad]
#2843320
11/08/20 12:03 AM
11/08/20 12:03 AM
Posts: 10,565 Freeport IL USA
poorboy
Freeport IL USA
One more thought on this subject, you can see in my 1st picture the Dakota factory wheels have a pretty big negative offset (the part of the wheel that bolts to the hub is very close to the outside edge of the part of the wheel the tire mounts to. Compare how the tire sits to where the lug nuts are located between the 1st picture (Dakota wheels) and the 2nd picture (not Dakota wheels, both are wheels are 15" x 7" wide). A 93 Dakota has the 6 bolt wheels, but by buying just the rotors (1988 to 1990), you can switch the front to the 5 bolt wheels with the 4 1/2" bolt circle. Bolting on a set of not Dakota wheels (5th ave, or most other older Mopar wheels) that have the wheel mounting part more centered with the tire will shift the wheel track out about 2" total, A wider width wheel with a deeper dish (the part of the wheel that bolts to the hub that is closer to the back edge of the tire) makes the track width even wider. You are actually moving the tire away from the ball joints. You will want to keep in mind that the farther away from the ball joints you move the tire, the more stress it puts on the wheel bearings. Gene
[Re: poorboy]
#2844719
11/11/20 12:12 AM
11/11/20 12:12 AM
HWC
Great Falls, MT
Dear Poorboy, They say you are the resident expert on Dakota swaps. Do you think a 1955 Dodge 5 window 1/2 ton pickup will fit on a 1993 Dodge Dakota frame (with front and rear axle)?
I can do the firewall and floor fabrication, as well as body mounts, etc, but I am concerned about tire track and the way it will look.
Thank you, I real appreciate any help you can provide. Wayne
[Re: HWC]
#2845068
11/11/20 08:50 PM
11/11/20 08:50 PM
poorboy
Freeport IL USA
Lots of guys have done Dakota frame swaps, some with a lot of experience on newer stuff (after 96) then I have.
In answer to your question. I think a 93 Dakota chassis will work well under a 55 Dodge 1/2 ton pickup. The width of the Dakota front and rear suspension (the rear suspension is good, but a Dakota rear axle is going to be 4" more narrow then your 55. You may have to put a mini tub in the box sides to clear a Dakota rear axle) is probably about the closest to the width of your 55 Dodge of any modern chassis. You may have to use the Dakota wheels on the front, but a lot of that will depend on the look you like, rather then a requirement for tire clearance. I will warn you that the lower you want the truck to sit, the more of an issue front tire clearance becomes. At normal ride height, I don't foresee any problems.
You are probably going to have to shorten the wheel base (the distance between the front axle and the rear axle), I doubt the Dakota donor you have will have the correct wheel base. A standard cab, short box Dakota will probably be too short of a wheel base, it is much easier to shorten the wheel base then it is to make it longer. A standard cab, long box Dakota is probably 7" -8" too long. Its pretty easy to remove 7" - 8" right behind where the back of the cab ends. An extended cab short box it probably around 18" too long. Gene
