Back With more charging woes
#2842096
11/05/20 12:01 PM
11/05/20 12:01 PM
Posts: 16,131 Mesa, Arizona
dart4forte
Mesa, Arizona
I’m having an overcharging problem. Here’s what I have
74 Dodge D100 with a 318 Running a Power Master 90 amp alternator. Changed the main power wire to 8 gauge Rewired underdash wiring eliminating the amp meter using the MAD diagram Wired in a volt meter wired off a 12 volt keyed source Running an MSD 6A Running a fresh VR that’s grounded to the black Ground straps from the frame to the block and from the frame to the core support Running Crackback HL relay kit Did an overall check of the wiring and it’s pretty solid
What’s happening is when the truck is started it shows a charge of 13.5 volts on both the gauge and my ohm meter.
After giving it a few blips of the gas the gauge and the meter jumps up to 14.5 volts to 15.5 volts with the needle on the gauge jumping back and forth. It also shows a fluctuation on the ohm meter with the same results. Also shows the same at the battery.
I’ve striped off all the tape from the VR wires which the wires appear to be ok. Jiggled the wires and no change.
I mounted my spare alternator and have the same results. I’ve replaced the VR with several spares I have and have the same results.
Also to note the lights also flicker in tune with the needle on the volt meter. Lights don’t flicker at idle.
I unhooked the HL relay and went back to stock, no change.
Any suggestions?
Abe Lincoln
Re: Back With more charging woes
[Re: dart4forte]
#2842102
11/05/20 12:18 PM
11/05/20 12:18 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Try a different, known to be good battery. Long shot, but easy.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2842116
11/05/20 12:55 PM
11/05/20 12:55 PM
dart4forte
Mesa, Arizona
Try a different, known to be good battery. Long shot, but easy. Had the battery checked at two different places. Checked out good.
Abe Lincoln
[Re: 5thAve]
#2842120
11/05/20 01:00 PM
11/05/20 01:00 PM
dart4forte
Mesa, Arizona
What does the VR plug and wiring look like? I've seen where something wrong with that will cause issues.
Since everything goes thru the dash volt meter is it worthwhile bypassing that to get it out of the picture? That's more of a question then comment. I know they can cause problems but don't know if that would cause this one. Did that yesterday. Dis connected the voltmeter and checked with my ohm meter. No change
Abe Lincoln
[Re: dart4forte]
#2842133
11/05/20 01:21 PM
11/05/20 01:21 PM
dart4forte
Mesa, Arizona
If I convert to a one wire configuration would that eliminate all the stock wiring from the VR? One the red wire from the VR, it runs off a pig tail across to the ballast resistor which I have jumped due to the MSD.
Abe Lincoln
[Re: dart4forte]
#2842414
11/06/20 03:17 AM
11/06/20 03:17 AM
Posts: 3,876 Oregon
hooziewhatsit
Using a voltmeter, measure between the positive on the battery, and the blue field wire at the alternator. This should be close to 0v. If it's higher, something between the two has higher resistance and is causing the voltage drop, so the alt/regulator are regulating them selves to the proper voltage, causing over-voltage at the battery.
[Re: hooziewhatsit]
#2842432
11/06/20 07:53 AM
11/06/20 07:53 AM
Posts: 10,702 North Dakota
6PakBee
North Dakota
Using a voltmeter, measure between the positive on the battery, and the blue field wire at the alternator. This should be close to 0v. If it's higher, something between the two has higher resistance and is causing the voltage drop, so the alt/regulator are regulating them selves to the proper voltage, causing over-voltage at the battery. Good suggestion but I would check the voltage on the blue wire at the regulator as that is the reference voltage the regulator is using. Theoretically the voltage at the alternator would be the same as that at the regulator (still talking blue wire) but there may be a harness problem. The statement that when the engine is started the voltage is fine but after a few blips (and the resulting engine movement) the voltage is high leads me to suspect a bad connection. Shoot, it could be a problem with the plug on the regulator. Just have to cover all the bases.
[Re: 6PakBee]
#2842509
11/06/20 11:38 AM
11/06/20 11:38 AM
dart4forte
Mesa, Arizona
Using a voltmeter, measure between the positive on the battery, and the blue field wire at the alternator. This should be close to 0v. If it's higher, something between the two has higher resistance and is causing the voltage drop, so the alt/regulator are regulating them selves to the proper voltage, causing over-voltage at the battery. Good suggestion but I would check the voltage on the blue wire at the regulator as that is the reference voltage the regulator is using. Theoretically the voltage at the alternator would be the same as that at the regulator (still talking blue wire) but there may be a harness problem. The statement that when the engine is started the voltage is fine but after a few blips (and the resulting engine movement) the voltage is high leads me to suspect a bad connection. Shoot, it could be a problem with the plug on the regulator. Just have to cover all the bases. Good suggestions however I replaced the plug and wires alternator to VR. All the volt readings are consistent with one another. Fluxuates between 14 volts and 15.5. I even tested the small red wire in the harness going from the plug for the ballistic resistor to the Red VR wire. Once I get the alternator back I can go from there. As a note I installed my spare alternator yesterday day checked possible bulkhead connection problems. No corrosion in the connections, wiggled the connections while the engine was running with no change. Did I mention I hate wiring?
Abe Lincoln
[Re: wally426ci]
#2857525
12/09/20 10:04 AM
12/09/20 10:04 AM
dart4forte
Mesa, Arizona
Any updates? Same setup and I am getting random spikes while driving. If the VR was gone, I would think it would just climb all of the time.... Yes, here’s what I ended up doing. I converted My 95 amp Powermaster to a one wire. In addition, since the tech was inside the alternator he converted it to a 75 amp. I removed all the wiring along the firewall that had anything to do with the old charging system. I had previously modified the wiring going into and out of the bulkhead connector which eliminated the amp gauge. Used the MAD modification. Also, I tossed the fuseable links and replaced them with circuit breakers. Simple parts that cost about $30 at Orielys. I installed one of Crackedback HL relay kits. Now, the truck idles at 14 amps and cruises at 14.5 amps. With the lights on it idles between 13.5 and 14 amps and cruises around 14.5 amps. The HLs do not dim and my dash lights are bright. Now that my electrical has been sorted out I’ll start dabbling with the Sniper FI I have sitting on the shelf.
Abe Lincoln
