Best way to check a block for cracks,options? #2842079
11/05/20 10:56 AM
11/05/20 10:56 AM
moparAL Offline OP
moparAL  Offline OP
Best way to check a block for cracks,options? Thanks...
Re: Best way to check a block for cracks,options? [Re: moparAL] #2842117
11/05/20 12:59 PM
11/05/20 12:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
For iron blocks I believe magnaflux is still preferred with dye-penetrant an option for home use.
Re: Best way to check a block for cracks,options? [Re: John_Kunkel] #2842215
11/05/20 04:40 PM
11/05/20 04:40 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
For heads and blocks I use magnaflux with the yellow dust, very easy to see the cracks. For cranks I take to my buddy for the ultraviolet light and dye.
Re: Best way to check a block for cracks,options? [Re: moparAL] #2842272
11/05/20 07:49 PM
11/05/20 07:49 PM
Have it clean it thoroughly before having a good shop mag it so they are sure there are no cracks any where twocents scope\
I've had the bad luck of a regular shop mag a set of 906 heads that they said where good only to find out on the engine dyno that one head had a long crack under the center two exhaust ports between the head bolts and the exhaust ports whiney
that shop did a lot of Chevy and fords but not many Mopars work
I've seen probably 6 or more 906 heads cracked there in SO CA shruggy
