distributor rotor #2840845
11/02/20 06:08 PM
11/02/20 06:08 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
Has anyone seen a rotor with a t on the end with more of a contact point. they sell them for everything but a mopar. I though i saw one now I can't find it. Thks Danny
Re: distributor rotor [Re: plycuda] #2840941
11/02/20 08:50 PM
11/02/20 08:50 PM
You could likey drill out the rivet & sub in one from another type. I would think if you got your rotor phasing on the money that you would not need a wider blade. keep all edges sharp & set the gap at .015"
Re: distributor rotor [Re: RapidRobert] #2840961
11/02/20 09:28 PM
11/02/20 09:28 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I run nitrous and not all the time so when I'm riding around It would be easier to phase it if its a little wider. for both motor and bottle
Re: distributor rotor [Re: plycuda] #2840968
11/02/20 09:47 PM
11/02/20 09:47 PM
^^^ Makes sense. if a wider one from another brand fits you might sub it in
