Proforged fast ratio pitman offsets drag link
#2839778
10/31/20 02:42 PM
10/31/20 02:42 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
Installed a Proforged pitman and idler arms, and the drag link looks like it's shifted at least an inch from center. There's no master spline, so you install for best fit, I guess. With steering wheel straight, master straight up on the box, judging by where the inner tie rods sit in relation to the torsion bars, there's about a one inch difference. Pulling the pitman and moving it one spline over moves the tie rods exactly opposite of what they were before. Just eyeballing the spindles, I need to make one tie rod half an inch longer than the other to point the tires straight. Is this offset normal from the factory, or using regular parts like Moog, and I only noticed because I had to index the pitman myself? Would this cause any handling problems one could feel or notice?
Re: Proforged fast ratio pitman offsets drag link
[Re: 375inStroke]
#2840018
11/01/20 07:26 AM
11/01/20 07:26 AM
Posts: 5,777 ohio
ruderunner
ohio
Just for fun, I'd drop the linkage and cycle the box lock to lock and verify it is in the center of travel. It may be that the master on the box is off.. It may be that the pitman has the splines clocked wrong. With the box truly centered, the pitman should point straight back.
1/2" difference in tie rods wouldn't worry me too much
Angry white pureblood male
[Re: ruderunner]
#2841244
11/03/20 01:15 PM
11/03/20 01:15 PM
375inStroke
Seattle, WA
Steering wheel and steering box straight up, everything shifted right. Move the pitman over one spline shifts everything left of center the same amount. I don't have a small sector shaft pitman, so I guess I'll try this for now. I'm just concerned about my bump steer. If the quick ratio feels good to me, I'll measure it and try to correct it, but this has been in my driveway too long. Driver's side inner tie rod shifted 1.25" right of the LCA pivot. Looking straight back, steering box sector shaft in relationship to the pitman arm ball socket. Passenger side shifted over .25" right.
[Re: 375inStroke]
#2841301
11/03/20 02:51 PM
11/03/20 02:51 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
I installed a new Proforged pitman arm on my Cuda and have the same problem. I have not got around to readjusting the tie rods yet to straighten out the steering wheel. Not an isolated problem, Put a new Moog pitman arm on my 96 Silverado and the wheel is off quite a bit now.
The only Carbs I care about are under the hood!
[Re: 375inStroke]
#2841306
11/03/20 03:16 PM
11/03/20 03:16 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I suggest that you also install a smaller diameter steering wheel to really help notice the slightly quicker fast ratio... at least the TUFF steering wheel (OE = 15" diameter, Flaming River = 14" diameter... I'm pretty sure its the Flaming River TUFF wheel that has the 14" diameter... GRANT's TUFF wheel is 15" ). Otherwise, it won't make a lot of difference, just slightly noticeable. Better yet, consider a 13.5" or smaller... I use a 11.5" diameter and the steering is very nice and truly fast responding! Don't be concerned about any extra effort.. our power steering is more than well assisted... be certain to use ONLY a Saginaw pump... the Federal pumps cannot keep up with fast-acting steering response.. it'll literally go away (no power assist!) under quick action, especially L-R-L-R...
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2842641
11/06/20 05:45 PM
11/06/20 05:45 PM
375inStroke
Seattle, WA
Is this an autocross thing? I've never done that. My only racing is on road courses with mostly big, fast turns, and the stock steering ratio felt fine to me in that environment. I made a lot of changes, so the car feels totally different now, but you're right about the ratio. I haven't noticed it being much faster.
[Re: 375inStroke]
#2843962
11/09/20 12:19 PM
11/09/20 12:19 PM
Mopar Mitch
Is this an autocross thing?... definitely helps! Road course?... helps as well! As per my suggestion, the combination of the longer arms (pitman and idler), with a smaller diameter steering wheel.. is where you'll truly notice the difference... and the overall result will be very satisfying.
Mopar Mitch
[Re: Mopar Mitch]
#2859155
12/12/20 11:00 PM
12/12/20 11:00 PM
Posts: 686 Houston, Texas
FastOrange
Houston, Texas
Not trying to completely hijack your thread, But, I have been having similar issues trying to align my 1970 Challenger. Originally a power steering 318 car. At some point years ago, I swapped to a manual box and the longer stock steering column. Then I purchased a quick ratio box (used, cant remember which brand, flaming river maybe? Been to many years ago). I also swapped pitman arms at some point years ago. Don't remember which one I have now, but it was a stock replacement from O'reilly I believe. I also added an aftermarket steering column to gearbox coupler. I have fully adjustable upper control arms to boot. I'm doing my own alignment but man, I'm having issues. Starting all over from scratch with suspension height etc.... I'm wondering if the pitman arm might be incorrect for my suspension? I'm about tired of wiping up the garage floor with the shirt on my back! Ackerman angle seems to be off. Also, I can't seem to center the steering wheel (stock) itself. If I turn the steering wheel lock to lock and go back to center, its not even close to being centered. I have my own turntables and alignment tools. I can't remember, but do you or anyone else know if the steering wheel has a master spline? How about the steering box and steering column splines? Do they have a master spline? I honestly cant remember. Worst case I take it back apart and look at all the splines. I think I will just copy and paste this onto a new thread.
[Re: pro451bee]
#2867215
12/31/20 10:14 PM
12/31/20 10:14 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
Use a shim under gear box mount to shift every thing closer to center. Thats how the factory corrected for tolerance stack. Are you suggesting moving it over or angling it? Sounds like this Proforged pitman is not made correctly. If this came to me as a repair for a driver with bias tires. I'd probably send it out the door with one tie rod assembly 1/2" longer and the other side 1/2" shorter. Anything else, yes I would want this all equal and centered. Compensating for these inferior parts just make me frustrated with the junk they sell for these cars. Does a stock pitman arm center the centerlink?
[Re: Magnum]
#2867506
01/01/21 01:33 PM
01/01/21 01:33 PM
Posts: 6,225 nowhere
Sniper
nowhere
Use a shim under gear box mount to shift every thing closer to center. Thats how the factory corrected for tolerance stack. Are you suggesting moving it over or angling it? Sounds like this Proforged pitman is not made correctly. If this came to me as a repair for a driver with bias tires. I'd probably send it out the door with one tie rod assembly 1/2" longer and the other side 1/2" shorter. Anything else, yes I would want this all equal and centered. Compensating for these inferior parts just make me frustrated with the junk they sell for these cars. Does a stock pitman arm center the centerlink? I think I would cut a new master spline in the arm before I sent out something with unequal length tie rod assemblies, doing that also affects center to lock turn numbers and you will have a different turning radius, left to right.
