Milodon dragster style oil pan #2839453
10/30/20 08:53 PM
10/30/20 08:53 PM
St.Pete,Florida
lancer493 Offline OP
St.Pete,Florida
Is anyone using Milodon's dragster style oil pan #31160 (10qt.)? Specifically,I'm speaking about it's oil return or drainback capabilities.Would like to hear from those who have used this system.It looks somewhat questionable to me in the windage tray area.All input appreciated. Thank you,in advance. Bill
Re: Milodon dragster style oil pan [Re: lancer493] #2839536
10/31/20 12:56 AM
10/31/20 12:56 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Ive used it for the past seven years with Milodon’s external oiling system on my street strip application with no issues at all.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Milodon dragster style oil pan [Re: lancer493] #2839768
10/31/20 02:09 PM
10/31/20 02:09 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I have the 10 Qt pan works good except the oil pressure always takes a dip. level is full, I think it's because of the returning oil splashes back up creating tiny air bubbles which aerates the oil dropping the pressure.
Going to remove the plate and put in a screen see if that helps.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Milodon dragster style oil pan [Re: lancer493] #2839852
10/31/20 06:49 PM
10/31/20 06:49 PM
I did a search on Milidon site and wasn't able to find that part number? shruggy
The 9 quart boat pan ,part # 3133o, is for a motor with the oil being push to the front of the oil pan up near timing cover area in a V drive boat.
Not for street use in a car tskscope
The nine quart SS style pan part #311470 is fir drag racing cars, if you want low profile for street use I would look at some of the road racing pans with center sumps with kick out, they do work well also scope
Re: Milodon dragster style oil pan [Re: Cab_Burge] #2839918
10/31/20 09:06 PM
10/31/20 09:06 PM
St.Pete,Florida
St.Pete,Florida
Thanks for the input Cab. The pan I have is a brand new unit#31160. Looking at the Milodon site it appears that they revamped the front of this pan as folks wanted to use it with a Magnum crossmember and took a 1 quart bite out of the front of it and renamed it #31161 for external pickups and #31163 for internal pickups, with both new numbers being 9 qt. capacity vs. 10 qts. for the earlier pan without the front modification. Same basic design and windage tray. Summit still lists them all w/pictures but lists the early one that I have as unavailable. My chassis uses a fabricated front suspension w/no k-frame intrusion, so the early one fits with no issues.Also just found an old thread from quite a few years back on here and a reader had asked the same question I had asked.Another reader replied that he had called Milodon and they told him to run it as is, that drainback wasn't an issue with that windage tray that it came with.I was just wondering if anyone had anything to that. Thanks for the update as I had no idea that this was done but it probably is due to large volume of requests .Makes sense to me. Bill
Re: Milodon dragster style oil pan [Re: lancer493] #2840147
11/01/20 01:18 PM
11/01/20 01:18 PM
gregsdart Offline
gregsdart  Offline
I raced for about four years with the old style dragster pan. Even with 10 qts in it i would lose oil pressure if i used the brakes agressively at all. 499 indy heads, 7000 rpm max. If you run this pan, i would run an accusump system with 3qt capacity. If you can data log oil pressure then you can cut back on how much oil you have in the system. Maybe 11 or so total with at least 2 of those in the accusump till the finish line.
