Re: Engine block tumble deburr process
[Re: AndyF]
#2839505
10/30/20 10:57 PM
10/30/20 10:57 PM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not sure I would call it a deburr process. What is up with that one driver side lifter bore.
[Re: pittsburghracer]
#2839506
10/30/20 10:58 PM
10/30/20 10:58 PM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Never mind on the lifter bore.
#2839575
10/31/20 06:26 AM
10/31/20 06:26 AM
Posts: 3,068 Michigan
A727Tflite
A large Reman facility down in Missouri used to tumble them, back in the 90’s.
Most everybody I know is using a Wheel-A-Brator now - more intense blast and does a much better job, gets inside nooks and crannies.
[Re: mopar dave]
#2839633
10/31/20 09:31 AM
10/31/20 09:31 AM
Posts: 4,205 New York
polyspheric
New York
Make sure you get all the shot out of the block coolant passage ways
YES, and the oil passages
Boffin Emeritus
[Re: polyspheric]
#2839675
10/31/20 11:07 AM
10/31/20 11:07 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
YES, and the oil passages I had a bead in my oil passage to the head so it was a good thing I checked.
[Re: tubtar]
#2839730
10/31/20 12:49 PM
10/31/20 12:49 PM
Posts: 30,989 Oregon
AndyF
Wow.........that is a big part to tumble. It turned out really nice. What is the $$ to have something like that done ? They charged me $150 for two blocks. These are both 440 HP blocks that I had sitting under the bench. Figured I'd get them cleaned up and ready to sell.
[Re: AndyF]
#2839738
10/31/20 01:02 PM
10/31/20 01:02 PM
Posts: 9,388 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Thats not a bad price really since some shops charge 65 to bake and rinse a block and then its two more hours of self cleaning the oil passages.
What do they do if its say like a 70s smog gunked up pasty block, power wash it first or bake it? Cant see anyone putting a block with 5 lbs of sludge buildup in a tumbler.
Lifter valleys look great and could be painted/sealed without much prep.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2839891
10/31/20 08:26 PM
10/31/20 08:26 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Seems like a bargain. I just spent 85.00 having a block and set of heads baked , and they came back cleaner than I expected. I believe the EPA has some issues with the caustic soda soaking process. I don't know anyone that does it anymore , but the problem was what to do with the residue inside the tank after doing a bunch of parts. At the tech school I went to , they drained the tank , then shoveled the remaining goo into a 55 gallon drum.............this was early 80's and no one cared much how you got rid of the sludge. Now , you could probably still do it , but the permits would not be cheap.
[Re: tubtar]
#2840016
11/01/20 07:18 AM
11/01/20 07:18 AM
Posts: 6,379 Abilene, Texas
fastmark
Abilene, Texas
Seems like a bargain. I just spent 85.00 having a block and set of heads baked , and they came back cleaner than I expected. I believe the EPA has some issues with the caustic soda soaking process. I don't know anyone that does it anymore , but the problem was what to do with the residue inside the tank after doing a bunch of parts. At the tech school I went to , they drained the tank , then shoveled the remaining goo into a 55 gallon drum.............this was early 80's and no one cared much how you got rid of the sludge. Now , you could probably still do it , but the permits would not be cheap. Exactly. The shop I used had to stop because they could not find anyway to legally get rid of the wasted vat chemicals. The EPA started coming in shops and fining people for even having it on the premises. They bought a Hugh oven that really cooks the parts and turns the gunk into powder. They used the shot machine after that. They cleaned the blocks really well and I always clean and brush every hole. I never had a problem. His shot machine kept breaking so now he sends them out to be blasted.
