No tires mounted. Will be using a factory color, in my case F8, which I can have mixed and put into a rattle can.
So........How's this sound ?
Sandblast
Clean / wipe down
Etching primer, wait 60 min
Epoxy primer, wait 60 min.
Color coat, maybe several coats, each coat while previous coat is still tacky.
Wait 24-48 hours
Rattle can clearcoat
Assuming I can spray with no runs, my goal is mostly a semi-durable finish, that should look "OK".
Car will never see snow/salt, hopefully not even rain.
I would powdercoat, but I don't think you can get autobody color-matching powder.
