Page 2 of 5 1 2 3 4 5
Re: 144.00 mph in FAST [Re: dvw] #2837142
10/25/20 12:43 AM
10/25/20 12:43 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Originally Posted by dvw
Originally Posted by John Brown
No doubt the mineshaft air helped to make the mph, but the cool track doesn't do a lot for traction. It's always a balancing act on skinnies.
I believe D/A was around 2000
Doug
Thought they were racing in Martin Michigan. Temps were in the mid 30's overnight and in the low 40's for most of the day here.
Didn't realize this was in Maryland. My mistake on the mineshaft air then. blush
Re: 144.00 mph in FAST [Re: DonnyBrass] #2837148
10/25/20 01:50 AM
10/25/20 01:50 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Black '71 Challenger for your next car, Mr. Dudek. wink
Mo' Farts
Moderated by "tbagger".
Re: 144.00 mph in FAST [Re: Grizzly] #2837212
10/25/20 10:29 AM
10/25/20 10:29 AM
Mo.
racerx Offline
racerx  Offline
Mo.
To anyone in the know ....is there a cut-off for the years allowed in this class? 144 mph is mind boggling runaway hell my car has been a bests of 142 and that's with aluminum heads and a Dominator.
Re: 144.00 mph in FAST [Re: racerx] #2837223
10/25/20 11:03 AM
10/25/20 11:03 AM
St Clair Shores, MI
DonnyBrass Offline OP
St Clair Shores, MI
55-79
Chevy infiltrator 12.34 @ 109.45 with a 1.73 sixty foot
Pure Stock
Re: 144.00 mph in FAST [Re: DonnyBrass] #2837331
10/25/20 04:09 PM
10/25/20 04:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
9.824 @ 144.0
Congrats to Dave Dudek and Rick Mahoney
Excellent job!!
9.776 ...... sweet up
Re: 144.00 mph in FAST [Re: fast68plymouth] #2837370
10/25/20 06:45 PM
10/25/20 06:45 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Congrats to Dave and Rick! That is an awesome performance from the HemiCuda. Long live Hemi power.
To answer a couple of questions, brake up grades are allowed, in the name of safety.
Rick Mahoney owns the Hemi Cuda, and Dave Dudek is doing the driving.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 144.00 mph in FAST [Re: Hemi_Joel] #2837486
10/26/20 08:32 AM
10/26/20 08:32 AM
an8sec70cuda Offline
That is incredible! Definitely making a LOT of power!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 144.00 mph in FAST [Re: an8sec70cuda] #2837504
10/26/20 10:27 AM
10/26/20 10:27 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
That’s got to be close to 800hp through stock intake, carbs and manifolds . How is that even possible? Are they still limited in the “sound” or can they go nuts on cams ? Would love to see one of these events.
2 kids and a dog
Re: 144.00 mph in FAST [Re: TonyS451] #2837505
10/26/20 10:36 AM
10/26/20 10:36 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
That's what we were talking about at work this morning. I get ported heads, big compression and big cubes but it all has to suck through the tiny straw of an intake and carbs!
'63 Dodge 330
11.19 @ 121 mph
Re: 144.00 mph in FAST [Re: GY3] #2837509
10/26/20 10:49 AM
10/26/20 10:49 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I know, must be some serious modifications to the intake and exhaust manifolds
2 kids and a dog
Re: 144.00 mph in FAST [Re: TonyS451] #2837510
10/26/20 10:54 AM
10/26/20 10:54 AM
Seems like I recall on one of his old motors they cut open the intake, milled out a bunch of material, did a lot of welding, and basically made it a big single plane?
CHIP
Re: 144.00 mph in FAST [Re: TonyS451] #2837517
10/26/20 11:16 AM
10/26/20 11:16 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
And it has to exhaust through a two and a half inch exhaust system with exits in the stock locations, through mufflers that sound stock at idle.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 144.00 mph in FAST [Re: TonyS451] #2837519
10/26/20 11:20 AM
10/26/20 11:20 AM
South Bend
South Bend
Closer to 1000 than 800.
Re: 144.00 mph in FAST [Re: TonyS451] #2837522
10/26/20 11:32 AM
10/26/20 11:32 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I am guessing that is more than 900 probably close to 1000HP and probably not much over 500 inches - There is no limit on cams or engine size. What is done to those cars is unbelievable every thing is thought out - every ounce is removed that can be - The engines are extremely trick and they are not afraid to turn some RPM with them
Re: 144.00 mph in FAST [Re: DoubleD] #2837543
10/26/20 12:52 PM
10/26/20 12:52 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Actually, there is a 560 cubic inch limit on everything except Ford 385 series Lima motors can go to 620. Camshaft must produce a correct stock sound at idle.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 144.00 mph in FAST [Re: Hemi_Joel] #2837565
10/26/20 02:04 PM
10/26/20 02:04 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I was standing around the 1000' mark when Dave ran the 144 mph pass. My 5.7 Challenger is louder at WOT through the stock pipes than the 'Cuda. Very impressive to watch that car go down the track each time.
Re: 144.00 mph in FAST [Re: sixpakdodge] #2837573
10/26/20 02:29 PM
10/26/20 02:29 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I’d be curious to know what the cam specs might look like in an engine like that.
2 kids and a dog
Re: 144.00 mph in FAST [Re: TonyS451] #2837602
10/26/20 03:16 PM
10/26/20 03:16 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
900 lift roller
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 144.00 mph in FAST [Re: TonyS451] #2837606
10/26/20 03:19 PM
10/26/20 03:19 PM
AndyF Offline
AndyF  Offline
I have a feeling that the cam specs only tell you a small part of the story. I'm not up to date on FAST engine builds but the little bit I played around with this stuff years ago taught me that the relationship between overlap and low lift flow was really important. My guess is that the heads have been modified to reduce low lift flow which would then allow more overlap to be used. That was the trend a few years past, not sure if they are still on that track or if they have gone a different route. I think it gets extra tricky with Hemi heads. These guys are making NHRA super stock type of power levels but with a lot more restrictions. Of course, they do have more inches and more compression but no headers and no billet cross ram intakes. Very impressive. Can't even comprehend the amount of work that goes into something like that.
Be funny to watch one of these cars pull into the NHRA stock lanes sometimes. They look a lot more stock than any of the NHRA stockers.
Re: 144.00 mph in FAST [Re: AndyF] #2837615
10/26/20 03:33 PM
10/26/20 03:33 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
These cars make you second guess the need for lightweight aluminum wheels, Rear wheel tubs with huge sticky tires, gutted interiors, and many other race car parts that people think are must haves. People who have not heard of this type of racing think your crazy when you tell them how fast they go on such narrow tires.
