Lowering a Car for ET? #2838857
10/29/20 03:58 PM
10/29/20 03:58 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Is it worth lowering, and what kind of change in ET do you get.....I just eliminated my exhaust from underneath the car...Probably could lower it 3.5" now.
Re: Lowering a Car for ET? [Re: Dragula] #2838897
10/29/20 05:35 PM
10/29/20 05:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Lower CG on a fast car is a good thing.
Re: Lowering a Car for ET? [Re: Dragula] #2838907
10/29/20 05:50 PM
10/29/20 05:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
To me, the critical question is "does it affect weight transfer and launch?".
If none or minimal, go for it!
Boffin Emeritus
Re: Lowering a Car for ET? [Re: Dragula] #2838927
10/29/20 06:19 PM
10/29/20 06:19 PM
AndyF Offline
AndyF  Offline
It helps with aero. May or may not help with ET. Looks faster.
Re: Lowering a Car for ET? [Re: polyspheric] #2838971
10/29/20 08:12 PM
10/29/20 08:12 PM
gregsdart Offline
gregsdart  Offline
Thats how i understand it. You have to have the power to keep enough weight transfer for traction. So it becomes a balance of cg position and torque that can sustain weight transfer. Look at a modern prostocker launch versus a high ten second bracket door slammer launch. Then consider where thier CGs are and torque available for the first 10 to 20 feet.
Re: Lowering a Car for ET? [Re: AndyF] #2839062
10/29/20 10:49 PM
10/29/20 10:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Be interesting what effect just that exhaust location might have on aero, vs say slightly turned up, thru the hood, etc
Re: Lowering a Car for ET? [Re: polyspheric] #2839119
10/30/20 03:22 AM
10/30/20 03:22 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Make the car move forward, not up.
Upward motion is wasted energy. At least, that's my experience in motorsports. twocents
Mo' Farts
Moderated by "tbagger".
Re: Lowering a Car for ET? [Re: Dragula] #2839233
10/30/20 11:42 AM
10/30/20 11:42 AM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
My 72 Duster went quicker each time I lowered the front, picked up a solid tenth and atleast 1 mph.
Re: Lowering a Car for ET? [Re: als499] #2839291
10/30/20 01:29 PM
10/30/20 01:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
High CG and upward motion is not needed IF the car hooks. Raising CG acts like moving weight to the rear. My bet on a normal bracket car the gain will be small if any.
Doug
Re: Lowering a Car for ET? [Re: dvw] #2839304
10/30/20 01:53 PM
10/30/20 01:53 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yes it helps. It doesn't look like your using very many aero tricks.
On your car. There are many. You reduce drag when you lower
Re: Lowering a Car for ET? [Re: Dragula] #2839360
10/30/20 04:13 PM
10/30/20 04:13 PM
If your running slower than 150.MPH in the 1/4 mile it probably won't help a bunch, if faster than 150. MPH it will have more affect up
Re: Lowering a Car for ET? [Re: Dragula] #2839381
10/30/20 05:17 PM
10/30/20 05:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My junk liked the chin spoiler in the front and I drilled holes in the rear valance for air to escape both helped in et and mph a bit......
Re: Lowering a Car for ET? [Re: Thumperdart] #2839415
10/30/20 07:23 PM
10/30/20 07:23 PM
Dragula Offline OP
Dragula  Offline OP
Interesting responses.....Lack of empirical data makes this mostly opinion then....So here is my understanding:
I used to race RC cars, specifically Dirt Oval as a sponsored driver, and they are not moving at 150mph, but aero plays a huge affect on handling and stability. A good handling car makes faster laps and generally finishes higher in the standings...Even at relatively low speeds like 30mph....
So when I look at my Duster, it sits higher than my Cuda and couldn't be lowered due to the headers. Now that those are out of the way, I can now lower a bunch.....What the results are, I have no idea.
My plan is to lower it, and put a chin piece on it....and then get it re-scaled and the IC changed if needed..
Re: Lowering a Car for ET? [Re: Grizzly] #2839455
10/30/20 08:54 PM
10/30/20 08:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well my thinking, and NOTHING matters except what a Wind tunnel indicates and a time skip proves, is the directed exhaust out the side in the OP's location could have significant "air curtain" effects on the side skirt area of the car that "could" be very beneficial, at speed, where traction is less of an issue.
Re: Lowering a Car for ET? [Re: jcc] #2839472
10/30/20 09:25 PM
10/30/20 09:25 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I know most of your racing is 1/8th mile where aero mods will have the least effect. Ideally I think you need to test it with the new headers before you do anything else. Just to see if they help or hurt performance.
68 Barracuda Formula S 340
Re: Lowering a Car for ET? [Re: jcc] #2839475
10/30/20 09:28 PM
10/30/20 09:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I get what you are saying but a Duster is already blasting a pretty big hole in the air as it is, not tons of air on the side of these cars I am willing to bet.
Re: Lowering a Car for ET? [Re: Bad340fish] #2839500
10/30/20 10:41 PM
10/30/20 10:41 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, 1/8 mile would likely show minimal bang for buck with aero, but how much does one need to be ahead of the other guy to win? work
Re: Lowering a Car for ET? [Re: Dragula] #2839631
10/31/20 09:29 AM
10/31/20 09:29 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Lowering the nose may increase your rear down-force
Boffin Emeritus
Re: Lowering a Car for ET? [Re: Dragula] #2839725
10/31/20 12:29 PM
10/31/20 12:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Where are you going to install the o2 sensor and your idle and low speed readings are going to be heavily skewed......
Re: Lowering a Car for ET? [Re: Thumperdart] #2839859
10/31/20 07:17 PM
10/31/20 07:17 PM
Dragula Offline OP
Dragula  Offline OP
I asked him to install one on the passenger side. Typically with short headers and no mufflers you really don't get an idle reading..I pick the car up tomorrow....So this will be interesting.
