Page 3 of 4 1 2 3 4
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28377
07/15/06 11:31 AM
07/15/06 11:31 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Shelton's 3rd power pull
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28378
07/15/06 11:34 AM
07/15/06 11:34 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
A sample of Shelton's idle/vacuum test
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28379
07/15/06 11:38 AM
07/15/06 11:38 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
INDY's Power #3 pull
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28380
07/15/06 11:41 AM
07/15/06 11:41 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
INDY's Idle/vacuum test
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28381
07/15/06 11:45 AM
07/15/06 11:45 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Stark's Power #3 pull
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28382
07/15/06 11:48 AM
07/15/06 11:48 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Stark's idle/vacuum test, he intentionally set the idle rpm high to help the vacuum # go up. We did similar thing, to help score as best as can.
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28383
07/15/06 11:51 AM
07/15/06 11:51 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Our # 3 power pull
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28384
07/15/06 11:56 AM
07/15/06 11:56 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Our idle/vacuum test. The motor actually idled at 605 RPM, but vacuum was obviously lower, and so we increased it to maximize scoring. Also because of the atmosphere in Colorado everyones vacuum #'s were aprox 2 lower than they were back in "normal" air. My motor was 8-8.2 inches here in PA at 775 idle.
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28385
07/15/06 12:00 PM
07/15/06 12:00 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Here are the atmospheric conditions during our pulls
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28386
07/15/06 12:03 PM
07/15/06 12:03 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Our oil pressure during pull #3
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28387
07/15/06 12:06 PM
07/15/06 12:06 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Graph of pull #3
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28388
07/15/06 12:10 PM
07/15/06 12:10 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
R&S Power pull #3
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28389
07/15/06 12:12 PM
07/15/06 12:12 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Hell, I'm impressed by everyone's results, not just the "big number" guys.
Gotta admit the correction factor for running in 8800 DA is pretty shocking, though.
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28390
07/15/06 12:15 PM
07/15/06 12:15 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
R&S Idle/vacuum sample
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28391
07/15/06 09:51 PM
07/15/06 09:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
great post!!
and...it sounds like it was a good time, despite all the BS up to that point.
i am confused about one thing though....you were mentioning the odd cam specs of the one entry...
("like I said in other post cam was very unusual, I'll be checking out exact specs on that on Monday from Comp. I've never even read a magazine article anywhere with specs like that cam has, such low duration (238 intake) and yet alot of lobe lift (.420ish)and a wide LSA")
......but i was under the impression the cam had to be an "off the shelf" item.
sooo.....which page of the Comp catalog is that cam on??
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28392
07/15/06 11:10 PM
07/15/06 11:10 PM
very informative thread. it looks like the folks at R&S had most everyone covered by nearly 100 Horsepower. do they do their own head porting? glad you were treated so well and had no fried wires.
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28393
07/15/06 11:46 PM
07/15/06 11:46 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
R&S Power pull #3
Wow
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28394
07/16/06 03:27 AM
07/16/06 03:27 AM
Eric working on his motor. When the big man puts his glasses on, you know he is getting serious In all seriousness, he is a blast to hang out with.
I recently sent some email to Eric asking about his 99 hemis. He was very informative and answered all my mails.
Re: MP Engine Contest Pics and Dyno Sheets [Re: fast68plymouth] #28395
07/16/06 12:40 PM
07/16/06 12:40 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
great post!!
Yeah..... you're going to get a call about that one on Monday. I'd like you to have a little chat with Chris May's about it. But no it's not in the "current" Comp Cams catalog.
DRAM they did'nt port their own heads, he told me who did them but it was not anyone I had ever heard of, it was just some small shop near them in MN. I got to see them during tear down, and we have some pics on the shops dig camera. They were nicely done, but nothing exotic. We were not allowed epoxy or welding etc. There was not any 1 component that made their power so much higher than everyone else, it was just a combo of everything.
They had 440 inches, as did most of us, but not all (Stark & Maurer built less)
They had 15:1, where most of us had alot less compression, We were about 12.1, Shelton 11.9, Stark 13.3. We all kind of stayed more in tune with "street motor" theme as far as compression.I know we could have got away with more in CO, but these motors now have to spend the rest of their life on the East coast at 1000-2000 feet DA, and we all took that into account. I really did'nt want to build a 15:1 motor that needs to run on $15 a gallon gas, if it's not in high elevation.
Their cam was "questionable" as far as legality of being an off the shelf grind
They had 1000 HP carb, one of the 2 biggest in the contest.
They had a Super Victor intake which obviously is a good piece.
The heads had oversize valves which we did'nt do because it was supposed to count against us cost wise, but that rule got changed the Monday night of the contest. I had stayed with the 3/8" MP 2.02/1.60 3/8 valves, used a cheap Comp roller spring, and moly retainers because of cost, they had oversizd 11/32's with Ti retainers etc. And did not get penalized cost wise due to the last minute rule change. So they had good heads...
They used 1 7/8 TTI headers, which would be the biggest ones used in the contest.
They had ~35 dyno pulls on it in MN, by far more tuning time than anyone else. We had 6 pulls in PA having issues getting on the dyno, and then having an adjuster back off and having to drive back to shop for backup rocker, Stark had about 1 pull as their dyno servo or something was messed up, INDY busted their intake rocker stud mounts due to aggressive porting, and had limited pulls due to fact they had to replace the block and make a stud girdle, and Shelton had bad valve seats and vacuum leaks and got limited tuning done.
They had 1 of only 2 roller cams
They had the highest overall MSRP cost even with the lack of cyl head parts included by a wide margin.
It all added up to the biggest power #'s, it was'nt one specific thing, just like in any engine it was the overall combo.
They pushed the limits of rules/cost/parts/and fuel farther than anybody and got away with it and won. They were by FAR and away the most prepared, and generally the best prepared is going to win. The lack of build time I think for them was helped out by the fact they were the only ones to subcontract out their head work. Everyone else did theirs in house, and with 30-50 hours+ eaten up right there.... that hurts. That would be my BIGGEST complaint about the whole contest, other than the constantly changing rules, it was just the overall lack of time from when we finally got our parts to when the motor had to be there. This was'nt like Enginemasters where you have half a year to work on stuff, this was a thrash.....
Re: MP Engine Contest Pics and Dyno Sheets [Re: RyanJ] #28396
07/16/06 02:19 PM
07/16/06 02:19 PM
North Dakota
Jesse_Lackman Offline
super gas
super gas
North Dakota
Ryan, what were the final scores?
Engine masters was NOT a thrash?? Grrrr...
Oh it looks like the A/F ratio is based on O2 (saw an O2 sensor on some of the pictures and the WinDyn channel is labeled LamAF1 for Lambda?), I'm wondering if a dyno calculated A/F ration was available, if so how did it compare to the Lambda O2 sensor A/F reading?
Page 3 of 4 1 2 3 4
