Engine compartment wiring question #2838557
10/28/20 10:57 PM
10/28/20 10:57 PM
MINNESOTA
Dean B Offline OP
Dean B  Offline OP
MINNESOTA
I have everything figured out on the wiring harness in my 74 roadrunner except for the connector in the attached picture. I cannot find a reference to this connector on any of the wiring diagrams. Can someone enlighten me on what this is for. I believe the two wires coming out of the harness and connecting together at the connector are blue.
Re: Engine compartment wiring question [Re: Dean B] #2838610
10/29/20 01:35 AM
10/29/20 01:35 AM
Looks like the ballast resistor 12 v feed wire to me shruggy
Re: Engine compartment wiring question [Re: Dean B] #2838619
10/29/20 05:19 AM
10/29/20 05:19 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Choke Electric control/switch
Re: Engine compartment wiring question [Re: NachoRT74] #2838630
10/29/20 07:36 AM
10/29/20 07:36 AM
MINNESOTA
Dean B Offline OP
Dean B  Offline OP
MINNESOTA
That makes perfect sense. Thanks.
