Is this a real tag #2837887
10/27/20 09:03 AM
10/27/20 09:03 AM
Ont, Canada
gygeneral Offline OP
Ont, Canada
Something on this tag bothers me, is it me? Its the 26, i've never seen it positioned in that location. Always on the top near the END.
Re: Is this a real tag [Re: gygeneral] #2837890
10/27/20 09:15 AM
10/27/20 09:15 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I'm no expert but the way the "5" in J52 and the R in R11 are offset higher looks fishy to me, I believe on legit tags the characters are always aligned horizontally.
Re: Is this a real tag [Re: Mastershake340] #2837891
10/27/20 09:17 AM
10/27/20 09:17 AM
Ont, Canada
Ont, Canada
This car sold at Barrett Jackson over the weekend for 110k, that will make 71B body guys happy. The only thing I am thinking this is a Windsor built car, maybe their tags were different
Re: Is this a real tag [Re: gygeneral] #2837912
10/27/20 10:21 AM
10/27/20 10:21 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’m sure Dan will chime in but nothing about that one looks correct to me.
Re: Is this a real tag [Re: gygeneral] #2838128
10/27/20 09:08 PM
10/27/20 09:08 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
Norm. looks like a repop, but I don't see anything wrong with the codes (or order of the codes). SPD and VON seem to fall in line with other Windsor cars I have with close VINs.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Is this a real tag [Re: Butterscotch71] #2838192
10/28/20 02:06 AM
10/28/20 02:06 AM
Maryland
MoparMike1974 Offline
Maryland
It also does not have the crease from where it was folded over for painting. Most (not all) tags will have this.
Re: Is this a real tag [Re: gygeneral] #2838200
10/28/20 05:24 AM
10/28/20 05:24 AM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
When the car at the factory was being painted, the fender tag was first mounted with the right screw in place and bent up slightly to allow the underneath of the inner fender surface to be painted. Then the left screw was fastened with another swipe of paint. The upper right hand corner usually had a 45 degree angle crease by the right screw from bending the tag.
Re: Is this a real tag [Re: Slotts] #2838201
10/28/20 05:52 AM
10/28/20 05:52 AM
Port Huron, Michigan
MI_Custumz Online content
MI_Custumz  Online Content
First thing that stuck out to me (no expert by any means), was the C all by itself to the left of the 26.
Re: Is this a real tag [Re: MI_Custumz] #2838225
10/28/20 08:51 AM
10/28/20 08:51 AM
Ont, Canada
Ont, Canada
I have the C on my car, it means it was a Cdn order car. Like I said this car brought a good price, but if you look at the car a lot of options were added that are not on the tag. Still a very nice car.So sounds like the location of the 26 is correct for a windsor car.
Re: Is this a real tag [Re: gygeneral] #2838396
10/28/20 03:54 PM
10/28/20 03:54 PM
Lost Title
Lost Title
Some of the options would not show on any 71 tag, and others aren't typically coded on Windsor tags. Fortunately the car has a broadcast sheet too (unfortunately it doesn't have any codes in several of the lines)
Re: Is this a real tag [Re: gygeneral] #2838432
10/28/20 05:08 PM
10/28/20 05:08 PM
STL
cdstl Offline
cdstl  Offline
STL
Should there be an Axle code?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Is this a real tag [Re: cdstl] #2838434
10/28/20 05:14 PM
10/28/20 05:14 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
EV2 on there twice?
Re: Is this a real tag [Re: AARCONV] #2838576
10/29/20 12:00 AM
10/29/20 12:00 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I would say it is a reproduction, but if they have a build sheet it would not matter much.
Re: Is this a real tag [Re: AARCONV] #2838629
10/29/20 07:35 AM
10/29/20 07:35 AM
STL
cdstl Offline
cdstl  Offline
STL
Originally Posted by AARCONV
EV2 on there twice?
Painted roof, no vinyl top.
Re: Is this a real tag [Re: AARCONV] #2838632
10/29/20 07:38 AM
10/29/20 07:38 AM
n.c.
geo. Offline
geo.  Offline
n.c.
EV2 on there twice?
Always when roof paint same as body color.
Re: Is this a real tag [Re: 4406bbl] #2838710
10/29/20 11:46 AM
10/29/20 11:46 AM
AndyF Online content
AndyF  Online Content
I agree. It looks like a reproduction to me (I'm no expert) but if they have a build sheet and it matches the build sheet then who cares. Not much different than if the car has a couple of reproduction fenders on it. None of these cars are 100% original anymore.
