4" stroke windage tray fitment
#2836870
10/24/20 11:40 AM
10/24/20 11:40 AM
RapidRobert
360 stroker. will the std windage tray used with the 4 main bolts with the long shoulders fit? Were there 2 different windage trays? thank you for your time.
Re: 4" stroke windage tray fitment
[Re: Sniper]
#2836887
10/24/20 12:14 PM
10/24/20 12:14 PM
RapidRobert
4" stroke crank/stock rods. someone has a set of those 4 long shouldered main caps & I wondering if I should grab em if this setup will fit EDIT main cap bolts I meant to say
[Re: RapidRobert]
#2837568
10/26/20 02:10 PM
10/26/20 02:10 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Similar to Neil's reply, I recently also used a Milodon windage tray with my new stroker ... there was lots of interference with the SCAT H-beam rods I used ... had to pound out and radius every throw on the windage tray... also set the adjustable height by using the Milodon studs into the caps. I spent at least 20 hours making the Milodon windage tray fit before I was satisfied... also the drain slots needed to be modified for extra rod clearance.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2838017
10/27/20 03:23 PM
10/27/20 03:23 PM
RapidRobert
are those (4) long shouldered main cap bolts still available or is their a substitute?
[Re: RapidRobert]
#2845156
11/11/20 11:52 PM
11/11/20 11:52 PM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
...I was under the impression that tossing a windage tray on a 4" (or larger) stroker setup was a bad idea...meaning, you would gain much more by going to a deeper pan instead. No hard evidence, just reading the on-line stuff, but that seems to have been the general common thread.
I am curious, b/c I have all the parts here to toss a windage tray in my 408 build, although based on what I previously found when re-thinking this approach I gave up on that idea.
[Re: Cab_Burge]
#2845234
11/12/20 10:43 AM
11/12/20 10:43 AM
RapidRobert
I havent yet read anything yea or nay about em on a 4" stroker but I will check further. yes crank scrapers get good reviews & I had forgotten all about em, thank you
[Re: RapidRobert]
#2845255
11/12/20 11:44 AM
11/12/20 11:44 AM
Posts: 82 New York
64 Sportfury
New York
I used a MP tray kit on my 318/390 Stroker. Took a bit of massaging with the stock pan.
[Re: Diplomat360]
#2845271
11/12/20 12:04 PM
11/12/20 12:04 PM
Posts: 168 San Diego
JP8
San Diego
I am curious, b/c I have all the parts here to toss a windage tray in my 408 build, although based on what I previously found when re-thinking this approach I gave up on that idea. I too was told, by my engine builder, that using the Milodon roadrace pan required no tray. I had bought the tray that goes with the LA roadrace pan and ended up selling it after I dropped all the other parts off at his shop.The bolt kit for that tray, sold as BBC kit, was obviously not needed either. I believe he said that no tray was needed on deeper pans and it maybe it was because of the the baffles, I don't know. It was about a year ago and I've got CRS syndrome.
Instagram : @5_points_racing
[Re: JP8]
#2845392
11/12/20 03:04 PM
11/12/20 03:04 PM
Mopar Mitch
Keep in mind... IF you actually road race, or do HPDE/HSAX/AX competition events, then the constant throw and sloshing of oil within the oil pan -- stock or Milodon style of design (i.e: pro-touring), will definitely be helped with control by using the windage tray. In other words, IF you actually DO NOT perform hard manuevers with your car (road race, HPDE/HSAX/AX)... then you could consider not using any windage tray.
Mopar Mitch
[Re: Mopar Mitch]
#2845648
11/13/20 10:09 AM
11/13/20 10:09 AM
RapidRobert
it'll be corner carving in the circle burner. I would likely use a stock type pan with some welded in baffles around the perimeter of the sump. it is a claimer motor so you dont want to go too crazy with expenses but with the virus I think there will be very little if any claiming.
[Re: RapidRobert]
#2845768
11/13/20 02:55 PM
11/13/20 02:55 PM
Mopar Mitch
Welded horizontal baffle plates (front, rear and both sides) in the stock oil pan will do just fine... it was the single best engine mod I ever did.. about 40+ years ago when I started autocrossing. Too bad MaMopar didn't have it as a factory stock design.
Mopar Mitch
