Crank Swap #2836809
10/24/20 04:47 AM
10/24/20 04:47 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Boogered up the forged crank in my 67 440. I have a cast crank, balancer and weighted convertor. Is there a problem using the cast crank in my older block while using the smaller flange thrust bearing?
Re: Crank Swap [Re: elmor353] #2836820
10/24/20 08:12 AM
10/24/20 08:12 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The cranks can interchange. Just use the right bearing for the block.
Re: Crank Swap [Re: elmor353] #2836925
10/24/20 01:56 PM
10/24/20 01:56 PM
Do you know if that cast crank had the bigger heavier H,D rods like the 1970/71 six pack rods or the same size as the LY rods?
If it was made with the heavier rods I would have the crank rebalanced for your motor twocents
Re: Crank Swap [Re: Cab_Burge] #2837585
10/26/20 03:01 PM
10/26/20 03:01 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
This crank came from a 77 engine. I don't believe it had the heavy rods on it.
