Re: 46rh Governor Questions
[Re: NITROUSN]
#2830577
10/08/20 09:43 PM
10/08/20 09:43 PM
Posts: 120 Florida
46rhRebuild
The check engine light was not on, which I thought was odd.
I wish I had had time to get an OBD 1 reader hooked up. The local auto parts stores don't have one (I've asked before), and I hadn't had issues that I couldn't diagnose myself with this truck, in years.
I got up to go to school, after having given up the night before, swapped the relay and depressed the schrader valve on the fuel rail after letting the fuel pump engage. I got a good squirt of fuel, and turned the truck over for grins. Fired right up perfectly. A good lhard test drive showed no signs of further issues. I chocked it up to a bad fuel pump relay and drove to school. Trans and engine worked perfectly.
Got out of school about 8 hours later, truck baking in the Florida sun. Ran like absolute garbage. I barely got 300 yards down the road. Check engine light still wasn't on.
I am not experienced enough with transmissions to know if this is an internal issue in the transmission. My common sense says no, because other than the sticky governor, it's worked perfectly. I suspect that they could have damaged that sensor during the install, or that the fuel pump is just going out.
I appreciate your help, Nitrous. I will post everything that they tell me.
[Re: NITROUSN]
#2835173
10/20/20 05:20 PM
10/20/20 05:20 PM
Posts: 120 Florida
46rhRebuild
I got the truck back from the shop yesterday.
They kept it and tried to get it to replicate the issues that I was having. They were unable to, thankfully said that they were uncomfortable replacing the fuel pump, and just put some fuel dryer in the tank. For the diagnostics and the fuel dryer I was out the door for $89.
I got the truck most of the way home and then it started doing the exact same thing. I guess it would only act up when the truck was hot, running at highway speeds in overdrive. I limped the truck back to the shop. They diagnosed a bad distributor component. They replaced the whole distributor and the truck only missed twice minorly on the way home yesterday. Bill was $260. Super honest people, and their prices are VERY good.
Driving back home today from school I was doing 1800 to 2000 rpms in overdrive and it started missing. Every ten or fifteen seconds it will miss and lurch alittle. Not nearly as badly as before, but very noticeably.
What in the world am I facing here? This is all new, post transmission rebuild.
[Re: NITROUSN]
#2835854
10/21/20 08:47 PM
10/21/20 08:47 PM
Posts: 120 Florida
46rhRebuild
The plugs and wires have less than 10k miles on them, but I will swap them if you think it's possible something has gone bad in there, Nitrous.
I'm using NGKs, but have heard good thing about Champions, for the 5.9L Magnum.
[Re: NITROUSN]
#2835881
10/21/20 09:34 PM
10/21/20 09:34 PM
Posts: 120 Florida
46rhRebuild
Thank you, I will follow that TSB down now, Nitrous. I will call the shop and ask them if they set the sync signal, tomorrow after class. They're really helpful so should be a non issue if it needs to be adjusted. Found it. Here's the link for anyone else who might need it. I also have it saved as a pdf, in case link is down I can email it. https://testing-public.carmd.com/Tsb/Download/31575/080022dc80bbf784Nitrous, do you recommend running some injector cleaner through, just in case? If so, any recommended products? The gas that I normally use is Chevron, so should have a mild cleaner in it. This is also the gas station that I may have gotten some contaminated fuel at, though.
[Re: NITROUSN]
#2836328
10/22/20 11:16 PM
10/22/20 11:16 PM
Posts: 120 Florida
46rhRebuild
The shop said that the fuel pressure tested ok, so they didn't change the fuel pump. They put a drying chemical in the tank and did a diagnostic.
Today I traced out the plug wires, following the TSB and did the best I could with it. I realized that one of the wires was laying on my passenger side header, cylinder number six. I replaced this wire because I just went ahead and assumed that it was damaged by the heat, as the plastic wire loom was burned. I also replaced the single ignition coil for the system, located near the idler pulley.
The truck ran better and only missed a few times on the way home. I also added half a container of marvel mystery oil to the tank when I changed the ignition coil. I noticed a power gain, whether it was from the coil or the mystery oil I am unsure.
When it missed today it felt the same as the other days, it was only the frequency with which it happened that was different.
I called the shop and they acted baffled when I asked about the distributor sync signal. They just said that they installed the distributor at TDC and hooked the wires up. I don't know what the sync signal refers to, honestly.
[Re: NITROUSN]
#2836448
10/23/20 11:54 AM
10/23/20 11:54 AM
Posts: 120 Florida
46rhRebuild
This shop has no idea what that adjustment is, so I may have to source another technician. I do not believe that this is something that I can do myself.
A call to the Dodge dealership let me know that they don't work on anything older than 2005. So I sent an email to the automotive department at my school to see if they'd be able to do this adjustment. I included the pdf from the link that you sent me, Nitrous. Thank you so much for your help.
