best oil psi gauge? #2835229
10/20/20 06:18 PM
10/20/20 06:18 PM
RapidRobert Offline OP
I want to add a mechanical gauge with the copper tube to my pristine 73 dart & I want to get a good one to lessen the chances of an oil leak on down the road. what brand(s) would you recommend? thank you for your time
Re: best oil psi gauge? [Re: RapidRobert] #2835289
10/20/20 07:52 PM
10/20/20 07:52 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Never had a problem with the AutoMeter mech gauges.
For that matter, even the cheapo ones.
Copper tube & proper installation = no problems.
Re: best oil psi gauge? [Re: topside] #2835314
10/20/20 08:33 PM
10/20/20 08:33 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Autometer for the race look.
You could go vintage Sun or SW for the nostalgia look with no problems either.
Re: best oil psi gauge? [Re: Sammy] #2835472
10/21/20 08:19 AM
10/21/20 08:19 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have an autometer that is probably 25 years old and still going strong, I just had it out of the car to change its place in the dash, zero leaks.
68 Barracuda Formula S 340
Re: best oil psi gauge? [Re: Bad340fish] #2835778
10/21/20 05:53 PM
10/21/20 05:53 PM
I'll check those out. thank you up
Re: best oil psi gauge? [Re: RapidRobert] #2835855
10/21/20 07:49 PM
10/21/20 07:49 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
AutoMeter's budget line is AutoGage; never had a problem with them, either.
But mine came with plastic line, which I replaced with copper.
Re: best oil psi gauge? [Re: topside] #2835890
10/21/20 09:22 PM
10/21/20 09:22 PM
Fulton County, PA
CMcAllister Offline
CMcAllister  Offline
Fulton County, PA
Autometer..
I've had copper break. I use -3 Teflon AN hose and hardware on everything except for the guys who want to get off cheap.
Looks better too.
Re: best oil psi gauge? [Re: CMcAllister] #2836031
10/22/20 10:24 AM
10/22/20 10:24 AM
agreed, I want to go with braided after I saw it on the autometer site. the copper would be better than nylon but still scary
Re: best oil psi gauge? [Re: RapidRobert] #2836034
10/22/20 10:28 AM
10/22/20 10:28 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
You can't use nylon for racing in the car.
I've used copper on my car for 45 years now. Never an issue.
Re: best oil psi gauge? [Re: CMcAllister] #2836109
10/22/20 01:08 PM
10/22/20 01:08 PM
moparx Offline
moparx  Offline
Looks better too.
i was going to say the same. i have used small [1/4"od maybe ?] hydraulic hose before that worked good, and was way cheap. [as in i had it here]
beer
Re: best oil psi gauge? [Re: moparx] #2836184
10/22/20 03:43 PM
10/22/20 03:43 PM
this is my daily driver,my new acquisition & I dont any mishaps so I will go with braided.
