Re: Edumacate me on HP Calculators
[Re: Dragula]
#2834935
10/20/20 10:18 AM
10/20/20 10:18 AM
Posts: 570 UK
rb446
UK
I use these 3 now, always used just the 1st one primarily which has worked out very close always> http://www.wallaceracing.com/accel-calc.php >>... play with the hp no. to get your slip results, take note of deficiencies/gains at certain parameters. Generally this calc shows 1+mph to what my cars and our current car have run but thats down to the 60's of course. >3000lb/input 688fwhp> 60 Foot E.T. : 1.32 1/8 Mile E.T. : 6.00 1/8 Mile Trap Speed : 113.20 1/4 Mile E.T. : 9.52 1/4 Mile Trap Speed : 141 http://www.wallaceracing.com/et-correction-eighth.php multiply hp shown x C/factor given http://www.wallaceracing.com/et-correction.phpFast uses the Moroso ruler which is as good if not better
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Dragula]
#2834952
10/20/20 10:49 AM
10/20/20 10:49 AM
Posts: 11,707 Portage,michigan
B3422W5
Portage,michigan
I am a little confused by the HP estimates of my car depending which one I use.
If I put in my ET and weight with me in the car, I get like 628hp, I change it around and put in weight and hp to calc ET and I get like 780 at the flywheel...Who uses what, and what am I doing wrong?
Car with me in it is 3000lbs, and best 1/8th mile ET is 6.00 at 114.5mph.....Best actual 1/4 is only 9.66 with a 6.15 in the 1/8.....earlier in the season. Trying to figure out what the 6.0 is for HP For comparison sake, the guy who bought my old car went 9.62@ 140. Car weight with him was 3220. It made 708 on the dyno when Best Machine did it. That time was on super stock springs, so pretty crude suspension. Figure 220 pounds less weight, about the same mph, probably an honest 660 ish horse When i had the car( few less go fast goodies) went 135@ 3350. Back then several guys had a thread on here, they were checking ET/ MPH against Moroso calculator That 135@3350 was 640 ish. Again, your weight, likely somewhere right between 640 and 700ish
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2834970
10/20/20 11:28 AM
10/20/20 11:28 AM
Posts: 19,358 Las Vegas
Al_Alguire
Las Vegas
MPH and weight will give you the answer to what HP you REALLY make. Its math and physics. How much HP does it take to move a given weight in a given time frame.
HP = (MPH ÷ 234)³ × Weight
[Re: Al_Alguire]
#2834991
10/20/20 12:00 PM
10/20/20 12:00 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
When my friend went from an auto trans to a manual in his GTO stocker it picked up about 5mph in the 1/4, which shows an almost 60hp gain in a trans swap. One takeaway there is........ the calculator results will only be as good as what the weak link in your combo is. His current Firebird Stocker will outrun the calculators in any kind of normal air. When you really want to know how much power your motor makes, you bring it to a reputable dyno service. If the car doesn’t run what it should, based on the power numbers....... start working on the car, and leave the motor alone. HP = (MPH ÷ 234)³ × Weight That works out fairly close for speed compared to the Moroso chart. A couple months ago a friend of mine bought a used bracket race engine. Brought it to the dyno, it made 728hp. A couple of weeks ago at LVD it went 9.10@145.88 at 2915lbs. On the Moroso chart the ET shows 734hp, MPH shows 695hp. If I use the above formula for speed it works out to 706hp.
[Re: fast68plymouth]
#2835045
10/20/20 01:33 PM
10/20/20 01:33 PM
Posts: 570 UK
rb446
UK
Using our cars details, 3800lb etc. our best et of 10.35@127+, we have run 130 once and some 128+'s.... 1.43>44 60ft's....the motor dyno'd@ 695hp@EDA entering all our info into 1/4m correction calc Your HP is 642.90 from your ET Your HP is 578.05 from your MPH Your HP Correction Factor is 1.05 Your Grains of water is 85.52 Your DA (Density Altitude) is 1,560 feet Your DA (Density Altitude) is 476 meters 642.90x1.05 = 675hp. Go to the http://www.wallaceracing.com/accel-calc.php calc enter 675hp/3800lbs you get> 60 Foot E.T. : 1.44 1/8 Mile E.T. : 6.54 1/8 Mile Trap Speed : 103.96 1/4 Mile E.T. : 10.36 1/4 Mile Trap Speed : 129 and we run with full exhausts, how much hp is lost there against the dyno's open hdr system you should be able to do exactly the same thing with your car/parameters and get similar results.
[Re: rb446]
#2835102
10/20/20 02:55 PM
10/20/20 02:55 PM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
My Moroso dream wheel says 9.65 @ 3000 is 620 and should going 139.
1/4 mile MPH is a better number to use. If you MPH is much more, or less, than 139-140, you are missing something depending on which way it's off.
Trans, rear, converter can easily eat up 15-20%, depending on how good or bad they are.
[Re: Dragula]
#2835107
10/20/20 03:19 PM
10/20/20 03:19 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Manual transmissions will mph better than automatics. Some TQs will eat more power than others. There used to be calculators that you needed to input the tranny type.
MPH is generally a better hp indicator than et, as et is also impacted by all the variables in the suspension, a lot.
The actual mph used in a calculator needs to be adjusted to standard conditions for comparison to dyno numbers.
The mph in calculators is net not gross like an engine dyno. Some adjust needs to be made there as well. The difference could be nearly zero in a race car, but sizable in a street car with exhaust and mufflers, water pump, fan, alternator, power steering pump air cleaner....
[Re: BSB67]
#2835116
10/20/20 03:32 PM
10/20/20 03:32 PM
fast68plymouth
So. Burlington, Vt.
The fact is, as converter, clutch, suspension, and tire technology has improved over the years....... if you make use of more of those technological advances....... you car can be quicker and faster at the same weight and power/weight ratio than it would have been 20-30 years ago.
Yet, the Moroso calculator has remained unchanged since its inception.
However, I still like to use it, along with good dyno data to determine if the combo is at least close to running up to its potential.
[Re: AndyF]
#2835132
10/20/20 03:54 PM
10/20/20 03:54 PM
fast68plymouth
So. Burlington, Vt.
In good air, but certainly not at all “mineshaft” air my friends Stocker will outrun the Moroso chart by about 10% on both ET and MPH.
In Vegas the numbers show within a few % of the STP dyno numbers, and that’s a track where his index is adjusted up by .19 in ET.
#2835147
10/20/20 04:26 PM
10/20/20 04:26 PM
BSB67
Prospect, PA
Sure. The calculators are emperically derived. They are not based on a black and white physics analysis. Transmission and TQ are the best examples. Efficiency changes matter, e.g. more time in the peak power band, more gears, lighter weight spinning internals......equate to more average power to the tire and faster and quicker car without more power under the hood. Change the weight of the tires/wheels will change et and mph, possibly in opposite directions.
My point is, lots of variables, and even if you attempt to account for them, it's still an estimate. The calculators are tools, just understand their limitations, and why.
[Re: BSB67]
#2835158
10/20/20 04:54 PM
10/20/20 04:54 PM
fast68plymouth
So. Burlington, Vt.
lots of variables, and even if you attempt to account for them, it's still an estimate. Exactly. If you play around with the numbers enough, in a few different calculators you can often come up with a set of numbers that make you feel okay about your combo...... as long as it’s at least somewhat “close”. But....... if you’re trying to actually improve the performance of the car...... someone is going to have to get out there and work on it
