Pics of MY custom A-body Headers #2834354
10/18/20 08:40 PM
10/18/20 08:40 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
Having a set built...Going to be a set of step headers 2-1/8 to 2-1/4 to a 4" collector I think.....Need to see how you guys did them, and how short can they be?
Re: Need pics of your custom A-body NA Headers [Re: Dragula] #2834529
10/19/20 10:18 AM
10/19/20 10:18 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Which front suspension are you running?? Can't help you if your car has a K-rframe, factory steering, and torsion bars. Good luck if that's the case.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Need pics of your custom A-body NA Headers [Re: jughed] #2834587
10/19/20 12:16 PM
10/19/20 12:16 PM
Magnum Force on mine...
Re: Need pics of your custom A-body NA Headers [Re: Dragula] #2834595
10/19/20 12:41 PM
10/19/20 12:41 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
These are 2 1/8"x2 1/4"x4" They are for sale but I don't know if they would fit with stock rails.
Re: Need pics of your custom A-body NA Headers [Re: Bigcube] #2834607
10/19/20 12:57 PM
10/19/20 12:57 PM
Those go out the fender?
Re: Need pics of your custom A-body NA Headers [Re: Dragula] #2834636
10/19/20 01:55 PM
10/19/20 01:55 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
The went over the rails and under the floor.
Re: Need pics of your custom A-body NA Headers [Re: Bigcube] #2834691
10/19/20 04:16 PM
10/19/20 04:16 PM
Tall deck or Low? For which heads did you have them on?
Re: Need pics of your custom A-body NA Headers [Re: Dragula] #2834698
10/19/20 04:39 PM
10/19/20 04:39 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Tall deck, indy -1 heads with a tube frame, Like I said I don't think they will work as-is with stock rails. Flange ports were big enough for B1's
Re: Need pics of your custom A-body NA Headers [Re: Bigcube] #2835021
10/20/20 12:57 PM
10/20/20 12:57 PM
Canada
RobR Offline
RobR  Offline
Canada
Nice Headers ! up
Re: Need pics of your custom A-body NA Headers [Re: RobR] #2836208
10/22/20 06:58 PM
10/22/20 06:58 PM
Well, I don't need pics of anyone else's....I got my own now. Not to mention, I won't be pro-streeting this car with this change.....Only one side is done so far. but looks really nice.
Re: Need pics of your custom A-body NA Headers [Re: Dragula] #2836224
10/22/20 07:37 PM
10/22/20 07:37 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Nice fab skills sawzall weld one thing i like about running though the fender is it allow you to lower the car some up
Also saves weight..........may be that 5.90's is in order smoke
Re: Need pics of your custom A-body NA Headers [Re: racerx] #2836228
10/22/20 07:42 PM
10/22/20 07:42 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
A[i][/i]. Nice!
Re: Need pics of your custom A-body NA Headers [Re: joes68340s] #2836253
10/22/20 08:26 PM
10/22/20 08:26 PM
Friend of mine makes headers....Took it to him. These are 2-1/8 to 2-1/4 step headers.....
And yes, the plan is to lower the car, put a chin piece on it, and I have a new short block going together. Should be around 520 cubes in a 440 block. The plan is a few more cubes, a little bigger headers, a little bigger carb, and a little bigger cam..And then this engine can be a spare unless someone has to have it..Not even 100 runs on it I think between since new last year.
Re: Need pics of your custom A-body NA Headers [Re: Dragula] #2836290
10/22/20 09:33 PM
10/22/20 09:33 PM
gregsdart Offline
gregsdart  Offline
Sometimes a different approach works well. These over the bar headers were within 1 hp of 2 1/4 dyno headers! The biggest thing was the straighter flow allowed further from the heads. They are 2 1/8 tubes and made 925 hp versus 926 hp with dyno headers on my 550 cube 440-1 motor.
Re: Need pics of your custom A-body NA Headers [Re: Dragula] #2836309
10/22/20 10:10 PM
10/22/20 10:10 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Those look great! Where did you purchase the pieces?
