Pics of MY custom A-body Headers
#2834354
10/18/20 08:40 PM
10/18/20 08:40 PM
Posts: 11,852 Taxes & Virus's R-US, NY
Dragula
Having a set built...Going to be a set of step headers 2-1/8 to 2-1/4 to a 4" collector I think.....Need to see how you guys did them, and how short can they be?
Re: Need pics of your custom A-body NA Headers
[Re: Dragula]
#2834636
10/19/20 01:55 PM
10/19/20 01:55 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
The went over the rails and under the floor.
[Re: Dragula]
#2834698
10/19/20 04:39 PM
10/19/20 04:39 PM
Bigcube
Upstate NY
Tall deck or Low? For which heads did you have them on? Tall deck, indy -1 heads with a tube frame, Like I said I don't think they will work as-is with stock rails. Flange ports were big enough for B1's ![[Linked Image]](http://www.bigcube.org/Winter07/WiresLeft.jpg) ![[Linked Image]](http://www.bigcube.org/Winter07/WiresRight.jpg)
[Re: joes68340s]
#2836253
10/22/20 08:26 PM
10/22/20 08:26 PM
Dragula
Friend of mine makes headers....Took it to him. These are 2-1/8 to 2-1/4 step headers.....
And yes, the plan is to lower the car, put a chin piece on it, and I have a new short block going together. Should be around 520 cubes in a 440 block. The plan is a few more cubes, a little bigger headers, a little bigger carb, and a little bigger cam..And then this engine can be a spare unless someone has to have it..Not even 100 runs on it I think between since new last year.
[Re: Dragula]
#2836290
10/22/20 09:33 PM
10/22/20 09:33 PM
Posts: 9,527 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Sometimes a different approach works well. These over the bar headers were within 1 hp of 2 1/4 dyno headers! The biggest thing was the straighter flow allowed further from the heads. They are 2 1/8 tubes and made 925 hp versus 926 hp with dyno headers on my 550 cube 440-1 motor.
8.77 153 mph best, 3055 lbs 528 indy 440-1 alky
[Re: Dragula]
#2836309
10/22/20 10:10 PM
10/22/20 10:10 PM
Posts: 2,964 Sac, CA
mopowers
Sac, CA
Well, I don't need pics of anyone else's....I got my own now. Not to mention, I won't be pro-streeting this car with this change.....Only one side is done so far. but looks really nice. Those look great! Where did you purchase the pieces?
