2.2 electronic ign?
#283434
04/10/09 11:18 AM
04/10/09 11:18 AM
Posts: 302 Casa Grande,Arizona
DennisJ
super street
super street
Casa Grande,Arizona
I have a 1984 Shelby Charger, that I bought new.
I would like to get rid of the computer and feedback carb. I have already modified a v8 dist. to fit the engine. I could run a single point ign. fairly easy.
What I don't know is if a Mopar electronic box will fire a four cyl engine. I will wire the cap with every other terminal being used.
The reason I want to do this is I have been having somekind of electrical gremlin at work. The engine will run fine for about ten minutes and then it shuts off.
I have tried replacing just about everything on the engine to no avail.
I will also be replacing the carb with a Holley 350 two barrel.
Thanks guys Dennis Jokela
I started out with nothing,and I still have most of it.
Re: 2.2 electronic ign?
[Re: DennisJ]
#283435
04/10/09 11:24 AM
04/10/09 11:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The symptom you describe sounds like the pick up in the dist.... quite common... after it heats up it goes open
[Re: MR_P_BODY]
#283436
04/10/09 02:55 PM
04/10/09 02:55 PM
DennisJ
super street
super street
Casa Grande,Arizona
The pick-up has been replaced. Also all the sensors have also been replaced. The computer has been removed and sent to Standard ign.to be tested..It passed, I also substituted another 84 computer no change.
I used to race this car in stock class when it was fairly new.
Dennis Jokela
