Page 1 of 4 1 2 3 4
For Sale - Small Block Engine - 4th Quarter #2826888
09/30/20 12:30 PM
09/30/20 12:30 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2827113
09/30/20 08:22 PM
09/30/20 08:22 PM
Metro Detroit
6PAX Offline
6PAX  Offline
Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
Original Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $35
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
Original Cal Custom 9" finned air cleaner top and base. No filter. $75
AC alternator bracket from a mid 70s 360. $15
Good used intake to water pump crossover hose from a mid 70s 360 with AC. $5
Mr. Gasket 1" thick carb spacer. $15
Small block passenger side biscuit motor mount bracket. $30
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
New Cloyes C-3028 small block Mopar timing chain. $25
Carb. throttle linkage stud. $10
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
Alternator date coded 1965. $60
Email: gt340 @ yahoo.com
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2827334
10/01/20 11:08 AM
10/01/20 11:08 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Ld340 intake. Was sanded down and polished sometime in the past. Should be easy to polish again if desired. Still has Chrysler part number 3549884 on it. One of the nicest ones I've seen in long time. Stock ports never touched, Never cut. And the bolt holes never altered or enlarged. May need one helicoil in thermostat housing. Been bead blasted, Washed and ready to bolt on.
$600 + $25 shipping to lower 48 states.
Can email me for quicker reply or more pics / questions?
Mcroft360@aol.com
Thanks Moparts!
W2 & W5 Small Block Hard Chromed Rocker Arm Shafts - New [Re: 727builder] #2828298
10/03/20 01:01 PM
10/03/20 01:01 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a couple new sets of small block Mopar offset drilled rocker arm shafts for W2 and W5 cylinder heads. These shafts are made here in the U.S. by a friend of mine. The shafts are made from thick 0.150" chromoly steel and hard chromed and can endure high spring pressure without flexing. They are much thicker than stock and Mopar Performance shafts - see photo. They feature banana groves and 3 oiling holes per rocker arm (one in the banana groove on the load side, one for the pushrod cup oiling and one under the rocker arm nose for valve stem oiling). All the holes are lightly chamfered to remove sharp edges. These are drilled off center for use with offset drilled rocker arm stands the hold down bolts. The ends of the shafts are threaded and have screw in plugs for inspection and cleaning. These shafts will provide the proper oiling to high load areas for adjustable iron and aluminum rocker arms.
Note that these shafts will not work for stock small block Mopar heads (273, 318, 340 & 360) or aftermarket cylinder heads including Edelbrock RPM, Indy LAX or other similar shaft mounted cylinder heads that require on center drilled shafts. I have a separate listing for stock replacement type shafts to use for adjustable iron and aluminum rocker arms.
Note stands in one picture are to illustrate the shafts installed in aluminum and steel offset drilled rocker stand blocks. The blocks and hardware are not included with these shafts.
Price is $300 for the pair of shafts including shipping within the lower 48 states. I can ship internationally for the additional shipping cost.
Contact procketrichard@hotmail.com for more information and pictures.
W2 Shaft 6.JPG (1190 downloads)
W2 Shaft 7.JPG (1184 downloads)
W2 Shaft 10.JPG (1183 downloads)
SB Shaft 9.JPG (1183 downloads)
Mopar Small Block H Beam Connecting Rods - New [Re: Rocket] #2828300
10/03/20 01:06 PM
10/03/20 01:06 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a set of 8 new Speedmaster H Beam connecting rods part number nart number:PCE274.1047. Specs are below. Note these us a small block Chevy wrist pin size of 0.927”. Speedmasters description on their site as well as other retailers lists these rods as have a SBM wrist pin size which is incorrect. I corrected this in the specs below.
Connecting Rod Length Center to Center (in): 6.123 in.
Connecting Rod Beam Style: H-beam Street/Strip
Connecting Rod Material: 4340 Chromoly Steel
Connecting Rod Finish: Shot-peened
Wrist Pin Style: Floating
Cap Retention Style: Through-bolt
Connecting Rod Bolt Brand: PCE
Connecting Rod Bolt Diameter: 7/16 in.
Connecting Rod Bolt Material: Chromoly steel
Fastener Yield Strength (psi): 200,000 psi
Connecting Rod Bolt Head Style: 12-point
Rod Journal Diameter (in): 2.125 in.
Pin End Bore Diameter (in): 0.927 in.
Big End Width (in): 0.927 in.
Advertised Horsepower Rating (hp): 700 hp
Advertised RPM Rating: 7,500 rpm
Weight Matched Set: Yes
Speedmaster sells these for $272. I will sell these new rods for $220 shipped.
PM me with questions
https://speedmaster79.com/H-Beam-6....340-Connecting-Rods-Chrysler-318-340-360
340 and 360 Ductile Iron 4 Bolt Main Cap Sets – New [Re: Rocket] #2828301
10/03/20 01:08 PM
10/03/20 01:08 PM
CT
Rocket Offline
Rocket  Offline
CT
I have a few sets of new ductile iron main caps available. These are Mopar Performance caps. I have sets for both 360 main and 340 main blocks. The sets include all 5 main caps. The center 3 caps are 4 bolt main. These are the same caps that came standard on R3 4 bolt blocks. I have installed these caps on a 340 before by milling off the ends of the center caps to leave them 2 bolt. See picture for the 3 modified center caps installed on a 340 stroker engine. These caps are more stout than the stock caps and are an excellent upgrade for any high performance build . A line bore will be needed when installing new caps as well as some machining for the thrust bearing and #5 cap oil seal.
Price is $230 shipped per set in the lower 48 states.
Email procketrichard@hotmail.com for more information.
Crower 1.7 lifters Magnum [Re: moparts] #2828328
10/03/20 02:25 PM
10/03/20 02:25 PM
Pittsburgh
72B7Duster Offline
72B7Duster  Offline
Pittsburgh
Located in the Pittsburgh pa area I have for sale a complete set (16) never used crower 1.7 roller rockers for a small block mopar magnum cylinder heads. All nuts, studs, washers, etc... are here and they are ready to bolt on and go. These are $799 new from summit Asking $520 plus shipping. Looking to sell to fund the next project in the shop. Thanks!!
New comp 280H cam, lifters, and springs [Re: moparts] #2828964
10/05/20 02:03 PM
10/05/20 02:03 PM
Wilmington - OH
57Royal Offline
57Royal  Offline
Wilmington - OH
Just like the title says, I have a new Comp 280H (hydraulic flat tappet) camshaft, lifters, and matching springs for sale. Asking $190 for all and includes shipping within lower 48. Here are the part numbers and current prices at Summit...
20-232-4 is the cam, $141.99
822-16 is the lifters, $97.99
901-16 is the springs, $63.99
Hopefully the link below works to the pictures but, if not, feel free to message me and I can send them to you.
[img]https://app.photobucket.com/u/dodgenut57/a/9c7f233a-1e52-4ce2-8be4-85e9fe3cb55b[/img]
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2831280
10/10/20 05:38 PM
10/10/20 05:38 PM
Sullivan, IN
Mopar Sam Offline
Mopar Sam  Offline
Sullivan, IN
Small Block Racer Brown Solid Roller Cam
This is a cast core Racer Brown solid roller 71R.
274 IN. 274 EX @.050. 590. 590 lift 105 lobe separation
Very good condition .
SOLD SOLD SOLD
Located in Sullivan IN 47882
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2831545
10/11/20 01:32 PM
10/11/20 01:32 PM
Nevada
X
x9daytonase Offline
x9daytonase  Offline
X
Nevada
Smallblock Mopar cam/lifter set (new) Part number P4120231AE $240. Plus shipping text 775 513 2317
4240 plu
Re:Partial set of used ARP head studs for the SB LA engines [Re: moparts] #2832668
10/14/20 11:25 AM
10/14/20 11:25 AM
Edison, New Jersey
PHYSIXX Offline
PHYSIXX  Offline
Edison, New Jersey
SOLD!!!!
I have for sale a partial set of ARP head studs, washers and nuts for the SB LA engines. There are only 4 of the bottom shorter studs but a few extra middle size studs. They are used but look to be in good useable shape. I would like to get $28.50 for everything shipped to any of the 50 States.
Edison, NJ
rider1454 at aol.com
Re:Partial set of used ARP head studs for the SB LA engines [Re: PHYSIXX] #2834070
10/17/20 09:56 PM
10/17/20 09:56 PM
Washington
skrews Offline
skrews  Offline
Washington
920 HEADS
Picked these from a member here a while back for my 318 project. Wound up selling the 318 the next week. Don't need these now. According to seller the heads have about 80k on them.
$120 OBO plus shipping
PayPal plus fee or USPS money order
located SE Wa 99323
Vintage M/T valve covers Clean $65pr [Re: moparts] #2834276
10/18/20 03:27 PM
10/18/20 03:27 PM
NH USA
littleredcoffin Offline
NH USA
The Baffle, Pcv, and block off plate for inside valve cover is in great shape. PCV rubber gasket is soft. Repainted with correct Wrinkle finish paint. In above average condition.1-10,these are solid 8.5..No cracks, never welded. No repairs ever..There is a slight paint thin spot by M/T on one cover.I will recoat before shipping. You will not find cleaner in this condition, for this price.$65pr.Calls only 603 209 1678.Payment will be by US POSTAL money order only.Please no Pm`s.I want calls only.
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2834318
10/18/20 06:00 PM
10/18/20 06:00 PM
K
ksm5150 Offline
ksm5150  Offline
K
Dodge R5P7 358CI 829HP@8400 $8,700 Shipped. Will look at trades. Will take Gen 2 Hemi or high performnce BBM Parts. Chevy high perf parts Side by side UTV.
$8,700 FIRM Shipped to lower USA. 2485631099 ksmconstruction@gmail.com
Comes with trans adapter to use mopar transmission.
Chip Ganassi racing built 358. Dyno sheet in pics.
Bought this fresh with dyno time only. Never ran it. Selling only to go to Hemi.
Bryant billet crank
Carillo rods
JEPistons
Flat tappit cam
11.5.1 compression
Titanium valves
PSI Valve springs
Jesel rockers
7/16 push rods
Dry sump with 5 stage pump and tank
New Cometic seals, New Clevite bearings, New JE rings
New Delphi alternator. High torque starter.
ATI balancer, CV Products billet fuel pump
Re: For Sale - Small Block Engine - 4th Quarter [Re: x9daytonase] #2834329
10/18/20 06:29 PM
10/18/20 06:29 PM
WV
Little Detroit Offline
WV
any idea of the specs ??
1968 69 318 Heads [Re: moparts] #2834433
10/19/20 03:56 AM
10/19/20 03:56 AM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
I have a pair of matching 1968/69 318 Heads. Heads came off a running engine and have been in dry storage since. They may run as-is but probably should be gone through. Part number: 2843675 They have 1.78 Intake and 1.50 exhaust valves. Dates: 02078 and 02108
$125
fas141@comcast.net
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2834968
10/20/20 10:19 AM
10/20/20 10:19 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
factory adjustable rockers, nice shape. cleaned and checked. correct banana groove shafts, normal wear. shafts cleaned inside with new plugs as well.
$280US shipped US/Canada
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2837745
10/26/20 07:27 PM
10/26/20 07:27 PM
Locomotion Offline
Locomotion  Offline
Harland Sharp 1.5 rocker arm kit/assemblies. S70025KE NEW (Some of the hold down clamps have some light rust blemishes.) They fit a variety of LA heads. I've used them on LA-X with 3/8" hold down bolts and OEM heads with 5/16" bolts.
$675.00 + shipping from Florida 32117
locomo@bellsouth.net
Factory Carb Stud With Wing Nut [Re: moparts] #2839123
10/30/20 02:38 AM
10/30/20 02:38 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Carb Stud With Wing Nut. Used, $15 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Call Steve 810-629-1097
73-74 Electric Choke #3656730 All Models [Re: Memongo] #2839124
10/30/20 02:39 AM
10/30/20 02:39 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
73-74 Electric Choke #3656730 All Models, Used, $35 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only! Call Steve 810-629-1097
Page 1 of 4 1 2 3 4
