440 stuff #2834165
10/18/20 10:47 AM
10/18/20 10:47 AM
Waterford MI
6PACKB Offline OP
6PACKB  Offline OP
Waterford MI
I have two 440's.
69 block that was machined, new cam bearings, steel crank turned, new rings and bearings. Fresh worked 906heads
71 complete rebuilt engine that had a cracked piston. Full set of replacement pistons included. Not six-pack rods/balancer, 906 heads
What are they worth?
Re: 440 stuff [Re: 6PACKB] #2834186
10/18/20 11:46 AM
10/18/20 11:46 AM
Macomb Michigan
65 Belv A990 Offline
Macomb Michigan
Looking for information on the 1969 block. Can you please tell me the blocks casting date, the stamped EAD and if it is stamped for HP internals?
MoPower..... Better to be a racer for a moment than a spectator for a lifetime.
Re: 440 stuff [Re: 65 Belv A990] #2834230
10/18/20 02:12 PM
10/18/20 02:12 PM
Waterford MI
6PACKB Offline OP
6PACKB  Offline OP
Waterford MI
11-3-68 casting
3-18 assembly HP stamp
Re: 440 stuff [Re: 6PACKB] #2834314
10/18/20 06:47 PM
10/18/20 06:47 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
What is the vin number on the right pan rail?
Re: 440 stuff [Re: fastmark] #2834569
10/19/20 11:34 AM
10/19/20 11:34 AM
Waterford MI
6PACKB Offline OP
6PACKB  Offline OP
Waterford MI
I will get a pic of that tonight.
Not one opinion of what these are worth?
Re: 440 stuff [Re: 6PACKB] #2834727
10/19/20 06:25 PM
10/19/20 06:25 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The 71 is a core motor plus the price of pistons. You need to mic everything to see if is a standard bore and crank. Cores go for $1000 or so tops. The 69 hp will bring a little more because of the hp. The machine work can help if it’s good. I’d say $2000. If the owner of the car can be found, then he would likely pay more. I have two friends looking for their 69 motors. It’s a long shot.
Re: 440 stuff [Re: fastmark] #2834767
10/19/20 08:07 PM
10/19/20 08:07 PM
Waterford MI
6PACKB Offline OP
6PACKB  Offline OP
Waterford MI
Vin is
9E152780
Re: 440 stuff [Re: 6PACKB] #2834869
10/20/20 06:38 AM
10/20/20 06:38 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ll alert Dan. I’m sure he wants to record it. That’s from an LA built car.
Re: 440 stuff [Re: fastmark] #2835136
10/20/20 04:00 PM
10/20/20 04:00 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
What about the #s on the 71 block,mine is missing.
440 cores are really bringing that much $$$$
Re: 440 stuff [Re: 71GTX471] #2835174
10/20/20 05:21 PM
10/20/20 05:21 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes for the good years. Things are not cheap anymore. Have you gone to the lumber yard? I almost passed out pricing a 1x8x12’.
Re: 440 stuff [Re: 6PACKB] #2835367
10/20/20 11:36 PM
10/20/20 11:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Vin is
9E152780
new number to me & I can't figure out for sure if it is a Coronet R/T (WS23L9E) 20% or a GTX (RS23L9E) 80% - the only 2 440HP cars built at LA for '69
